Re: Purchased 70 challenger se
[Re: Joemoy29]
#1030050
07/11/11 02:08 AM
07/11/11 02:08 AM
Posts: 1,300 Washington
19cuda73
Washington
Good Find Joe. Welcome to the site. Lots of information and the people are great. Pick yourself up a factory service manual when you can, I would keep it stock. what color ?
Dennis
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
[Re: Joemoy29]
#1030051
07/11/11 06:05 AM
07/11/11 06:05 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Rockauto carries a lot of mechanical parts, you can probally get brake parts from there. I like to do the front disc swap from mid to late 70s valares/aspens. There are quite a few other cars that you can swap from. If you can find the spindles and caliper adapters, it could be done much cheaper than for 450.
I'd try searching here for info on the se rear window.
A numbers matching 318 probally wouldn't make it more valueable than swapping in a 340 or big block. Myself, I rare keep them as 318 cars.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Joemoy29]
#1030055
07/11/11 10:56 PM
07/11/11 10:56 PM
Posts: 126 Canada
sam c
Canada
Hello thanks for the replies I have the parts for the rear window. But do you seal the fiberglass with any silicon? Thanks joe
I filled mine with seam sealer then glued the foam on top with 3m trim adhesive.
