Pilot Bushing/Bearing Question
#1029884
07/10/11 10:44 PM
07/10/11 10:44 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
1968 383. Here is a shot of the end of the crank. Engine is out of a B body, originally with an auto (I think).
It appears that this thing is ready to accept a pilot bearing, or am I wrong?
Thanks!
383, Hemi 4-Speed, AlterKtion, D60
Re: Pilot Bushing/Bearing Question
[Re: Cab_Burge]
#1029887
07/11/11 07:21 AM
07/11/11 07:21 AM
Crazy68Dart
Canton, Ohio
Okay, thanks. I can look at my 400 crank too, I guess. It is a later crank '77 I think, so I'm not sure it is going to tell me a whole lot. Might not even be drilled.
[Re: 451Mopar]
#1029892
07/12/11 07:31 AM
07/12/11 07:31 AM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
Andy, get the roller bearing from Mopar. It goes right in the register where the Torque Converter hub sits. Then you don't have to worry if the bushing area is fully machined to accept the bushing or not. The bearing usues a mid-late 90's Ram with a stick trans in it for an application. Been awhile, but I am pretty sure the part# is 53009180AB.
--Chad
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1029893
07/12/11 07:39 AM
07/12/11 07:39 AM
Posts: 1,260 Netherlands
72Challenger
Netherlands
Yeah, what Chad said! Just measure the depth of the crank hole to be sure the input shaft doesn't bind there when installing the box. These roller pilot bushings can be gotten at Summit or Jamie Passon.
[Re: 72Challenger]
#1029894
07/12/11 07:52 PM
07/12/11 07:52 PM
Crazy68Dart
Canton, Ohio
Thanks guys. I would rather not have to cut the input shaft, so what I have to work with appears that it won't be necessary.
[Re: rowin4]
#1029897
12/29/11 05:24 PM
12/29/11 05:24 PM
Crazy68Dart
Canton, Ohio
Didn't clean it cause it was on the engine stand at the time with parts piled around it. Now that I have it on blocks, there is a bushing in there already as a few of you mentioned.
I think I will go with the roller bearing. I can't see why it would hurt to leave the bushing there, so I'll probably just leave it be. Give it all a good cleaning of course.
Thanks all.
[Re: Crazy68Dart]
#1029899
12/29/11 10:26 PM
12/29/11 10:26 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Andy I would clean it up real good with scotch brite and leave that one in there if it's like new.If it looks worn then take it out and use the bronze one that you drive into the TC register. I use the one on the right in the picture you can get it at the Mopar dealer. Just a heads up when you build your stroker have the crank drilled for a Mopar input,my Eagle was not drilled deep enough and I had to whack the input on my brand new Richmond box Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1029900
12/29/11 11:23 PM
12/29/11 11:23 PM
Crazy68Dart
Canton, Ohio
Gus, thanks. I am going to do just that, clean it up real good and see if it is even worth messing with. I didn't know there were different versions of the larger style bearing. The needles worried me a little fearing that they could be a point of failure. Yeah, I'll need to look at the crank. It is an Ohio crank 4.15 stroke and probably not drilled. Either way, going to run the 383 for a while, but I should make a note somewhere so I don't forget.
