Searched it but didnt get my peace of mind.
Ok have a 451 installed the mopar .509 108 degree cam.I am at the stage of setting it up i am advancing this cam 4 degrees.I have my indicator on the #1 intake retainer.The heads are on because i am a scatter brain
I set my degree wheel by watching the piston through the plug hole.I brought it up,let it swing just till movement,then reversed it and slit the difference.
I set TDC to pointer,turned clockwise till max vlave opening measuring on the retainer.Then i zeroed the indicator.Backed off .75 then forward (clockwise) to 50 before max lift.I get a reading of 75.
Problem is i go on to .50 after max lift my number is to small to get a addition to make the divide by 2.I end up in the 90's or if i measure the other way from TDC i get to large a number putting it in the 130's.
I am sure the procedure to 75 egrees is right but after that it goes to shiii,what in gods name am i doing wrong?I did this 5 years ago didnt remember a problem??
I have one of those cheap Mr Gasket wheels 0-90-0 reading type.Is everything always measured in a clockwise manner?
The sencond reading after .50 before for .50 after doesnt roll around enough to get proper numbers.Example first seems steady at 74 and the roll around to .50 after isnt a big enough number to add up and split~
Also it has a 3 position crank sprocket,the 0 is to the left of the key.I installed straight up with the copper colored bushing in cam gear with the offset to the right?Meaning in a clockwise rotation the the skilly part of the bushing is on the right side of pin???
Garage is 110 degrees i do know that please help me out,i have a full head of hair but starting to get a little po'ed!
