Need help tuning my carburetor
#1029312
07/10/11 01:57 PM
07/10/11 01:57 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
I have a holley 650 double pumper on my 318 with headers, edelbrock performer rpm air gap and 3" true dual exhaust. This is for my 85 w150. If I step on it quick off the line it will bog really bad and I have to back off of the throttle to get it to stop. Also, whenever the truck is under load going up a hill, or if I give it full throttle even while moving, the truck hesitates real bad and will backfire out of the carburetor and pop out of the exhaust. When cruising down the road the truck runs fine. Timing is set at either 14 or 15 initial (cant remember) and 36 total. I adjusted the mixture screws for highest vacuum reading and Im getting a strong shot out of the accelerator pump as soon as I hit the gas. Any help appreciated,
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Need help tuning my carburetor
[Re: mikemee1331]
#1029314
07/10/11 04:07 PM
07/10/11 04:07 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
check your acelerator pump linkage...as soon as the linkage moves the squirter needs to squirt gas...
check the rear pump also...but it will not squirt gas until the rear throttle blades begin to open,,,,
also..at wide open throttle there should be .015 clearance between the pump arm and pump linkage...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1029316
07/17/11 06:08 PM
07/17/11 06:08 PM
73cuda340
clarks summit pa
Im starting to think that this is an ignition/ electrical related problem. Some days it will run absolutly awful and just cut out for a second and backfire when you give it gas and other times it will be fine for the entire trip. Does this sound right?
[Re: 73cuda340]
#1029317
07/17/11 11:28 PM
07/17/11 11:28 PM
RapidRobert
Some quick thoughts; assuming float level(s) good. ported or manifold vac? check dist pickup gap/plugs/wires/firing order/disconnect vac adv & see if that helps/hurts/no ch. Always done this (since built) or recent prob?
[Re: 73cuda340]
#1029321
07/20/11 01:18 AM
07/20/11 01:18 AM
Posts: 553 DE
Ply72rr
DE
Weak ignition will cause a miss or stutter under load.You said cap/rotor are new. Have you checked your plug wires,coil etc... If you have access to a old oscilloscope and can make it miss/stumble while loading against the brakes you could confirm or eliminate the ignition system as the problem. Good luck.
A lean condition could make it pop out the carb but shouldn't backfire out the exhaust. If the timing chain was off a tooth you would not have a intermittant problem,it would run weak and like crap all the time I would think. Let us know what you find.
[Re: dusterbd13]
#1029322
07/21/11 07:33 PM
07/21/11 07:33 PM
73cuda340
clarks summit pa
It just hit 102,000 miles. My original guess was the ecu went bad, because I had to put a new one in a little while ago and it wasnt long after that the problem started; but last night I installed a new one and it's still the same.
[Re: RapidRobert]
#1029324
08/07/11 09:46 PM
08/07/11 09:46 PM
73cuda340
clarks summit pa
Still trying to figure this out. I just installed a new coil and it's still the same. The backfiring mostly went away when I reset the floats; it doesnt really do it that often anymore but its still there. The misfire is definatly worse though.
[Re: 73cuda340]
#1029325
08/07/11 09:52 PM
08/07/11 09:52 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
What is your vacuum at idle and is the needle steady? Stock cam?
Is the carb out of the box or have you tweaked with the PV and jets?
383, Hemi 4-Speed, AlterKtion, D60
[Re: RapidRobert]
#1029327
10/02/11 07:26 PM
10/02/11 07:26 PM
73cuda340
clarks summit pa
I found out the backfiring and missing were caused by the sockets on the plug wires going into the cap. They loosened up and some werent making a good connection so I just changed the wires. My new problem now is that if I try to just start up the truck and go it will stall unless warmed up. The truck will stay running but as soon as you put it in gear and give it gas it will stall and has a bad hesitation. Nothing else has changed to make it do this. It has an air gap intake and since there is no cossover I expected some drivabilty issuses during cold weather, but it will even do this on a 75 degree day. Any help is appreciated.
