Differential Questions #1029116
07/10/11 01:45 AM
07/10/11 01:45 AM
TN
'84 D150 Shorty Offline OP
Pickup Man
Pickup Man
TN
Hey guys, hoping somebody can help me. I have a 8.25" axle. When i turn the axles back n forth, it clunks. I can grab the axle and pull (like your pulling the axle shaft put) and there is play. How much play is normal? Or should there be no play at all? Thanks for any info!
Re: Differential Questions [Re: '84 D150 Shorty] #1029117
07/10/11 01:56 AM
07/10/11 01:56 AM
Kansas
BEINGmeISaCRIME Offline
Kansas
Seeing as the axle shafts are only held in by C-clips a small amount of play is normal, a larger amount and by that like... 3/8" would definitely indicate a problem. If you were somewhere around 1/16 and 1/8ths I would think you'd be fine.
Re: Differential Questions [Re: '84 D150 Shorty] #1029118
07/10/11 01:59 AM
07/10/11 01:59 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
8 1/4" and 9 1/4" pickup axle shafts tend to have a lot of in-and-out play. This doesn't seem to hurt anything, however.
Re: Differential Questions [Re: DoctorDiff] #1029119
07/10/11 02:37 AM
07/10/11 02:37 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Doc said it all..
I am truckless..
Re: Differential Questions [Re: '84 D150 Shorty] #1029120
07/10/11 08:04 AM
07/10/11 08:04 AM
scratchnfotraction Offline
pull the inspection cover,then pull the cross pin to see if it is worn and causeing the spiders to have to much backlash/clearance.
I have had some that were worn bad and clunked going it to drive,old trick is to turn the pin and make it clunk going in to revs and not drive
spider set and a new pin has fixed a few of my clunky 8 1/4s and 9 1/4s right up
Re: Differential Questions [Re: scratchnfotraction] #1029121
07/10/11 11:33 AM
07/10/11 11:33 AM
TN
Pickup Man
Pickup Man
TN
The spider gears themselves seem ok, and the teeth on ring pinion and spiders all look ok. There does appear to be some looseness in the spider gear set though. Since some play is normal, would it help tighten things up a bit if I replace the shims under the spiders and installed a new cross pin?
Re: Differential Questions [Re: '84 D150 Shorty] #1029122
07/10/11 11:45 AM
07/10/11 11:45 AM
TN
Pickup Man
Pickup Man
TN
Oh yeah, and the passenger side axle had more side play for some reason, that normal too?
Re: Differential Questions [Re: '84 D150 Shorty] #1029123
07/11/11 04:45 PM
07/11/11 04:45 PM
TN
Pickup Man
Pickup Man
TN
Re: Differential Questions [Re: '84 D150 Shorty] #1029124
07/11/11 05:17 PM
07/11/11 05:17 PM
yes i have used new shims and spider gear set along with a new pin
pull the pin to see if thats where the slop comes from on the gears..i have just used new pins also
Re: Differential Questions [Re: scratchnfotraction] #1029125
07/11/11 07:26 PM
07/11/11 07:26 PM
TN
Pickup Man
Pickup Man
TN
How tight should the gears be on the pin??
Re: Differential Questions [Re: '84 D150 Shorty] #1029126
07/11/11 07:44 PM
07/11/11 07:44 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
they should rotate but not wobble
I am truckless..
Re: Differential Questions [Re: 340SHORTY] #1029127
07/11/11 11:38 PM
07/11/11 11:38 PM
TN
Pickup Man
Pickup Man
TN
Mine wobble :-(
