Carb rebuilding?
#1029035
07/09/11 08:57 PM
07/09/11 08:57 PM
Posts: 4,213 Williamsport PA North Central ...
13ChargerR/T AWD
I have a Holley 600(vac secondary) id like rebuilt RIGHT. Its going on a stock 340 its either that or rebuild the original TQ...right now a Eddie 750 is on it but its just not the right carb for it but at least it runs.(the eddie was for a much bigger cam and the butterflies were drilled a bit for it to be able to idle right with the larger cam in it so id just like to eventually get something new OR have the 600 rebuilt)
Im assuming on a mostly stock 340 with just headers and stock type cam that a 600 Vac Secondary holley would be a decent match?? Or should I be looking at something else...
Any recommendations on a place to rebuild the Holley 600??
Re: Carb rebuilding?
[Re: 13ChargerR/T AWD]
#1029036
07/09/11 10:08 PM
07/09/11 10:08 PM
Posts: 305 CA
David Lee
CA
just about any good speed shop that has a mechanic can rebuild it with no probs. I actually perfer the edelbrock/carter equivelent
Ah...so many pedestrians, so little time...
#1029038
07/09/11 10:37 PM
07/09/11 10:37 PM
Posts: 3,396 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Why wouldn't you consider trying to do it yourself? It sounds like you're not needing anything radical, just a basic rebuild. Shouldn't be that hard.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
