Re: Let me see your tunnel rams!
[Re: MRMOPAR622]
#1028824
07/11/11 02:11 PM
07/11/11 02:11 PM
Posts: 1,107 Quebec, Canada
Diablo
Quebec, Canada
Diablo,that's a nice looking set-up.What kind of set up is it? Looks like it might be terminators but not sure.Would like to know a little more about it,but can understand if you must keep it secret to protect your edge on the competition.
The intake is built by CFE. The throttle Bodies on top are Kingsler. They are very close to the Terminators but made by Kinsler. From what i've read a heard the air distribution is much better with the 4 intake throttle bodies compared to the one big toilet.
The 8 injectors in the Intake are for idle and lower rpm's once a pressure hits a certain point a poppet opens and the fuel starts injecting right behind the intakes valves. So kind of like direct port injection. This way the intake and heads are trying to flow as much air as possible with worrying about the alchy taking up to much space. And believe me this engine drinks A LOT of alchy. We will burn 3-4 gallons in one 300 foot pull.
This picture is a better shot of the front
Our other Ts engine has Terminators on it but only has the injectors in the intake.
[Re: Diablo]
#1028825
07/11/11 02:35 PM
07/11/11 02:35 PM
Posts: 8,857 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
426 hemi 2 1050 holley dom. carbs stock 6 pack/hemi lid 2 3" k/n filters
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: HardcoreB]
#1028835
07/12/11 12:25 PM
07/12/11 12:25 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
I used Aeroquip FC598-12 hose. The adapter is 3/4NPT so I used an alloy adapter from male pipe to 3/4" barb then hose clamped the line. The rad.-end uses Aeroquip pushloc -12 AN. I welded a plate to the radiator that I pre-welded 2 (-12) male AN's onto...replacing the original 1 1/2" hose barb.
Thanks! Got any pics you can post for me?
[Re: CrAzYMoPaRGuY]
#1028840
07/13/11 02:10 AM
07/13/11 02:10 AM
Posts: 6,570 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
My work truck for years....
Saw one of those at Carlisle with a 6 pak top for only $650 ![](/ubbthreads/images/graemlins/eeek.gif)
Did you make the 2x4 top for yours? I was told they were only made for Super Stock with a choice of 6pak or single four. Supposed to be about the best TR for a 440 and it will fit in a 6pak scoop.
Kevin
[Re: Twostick]
#1028841
07/13/11 10:11 PM
07/13/11 10:11 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
Mine was a converted 3x2bbl top. It worked well, had tons of torque and great top end.
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#1028842
07/13/11 10:25 PM
07/13/11 10:25 PM
