Page 2 of 4 1 2 3 4
Re: Let me see your tunnel rams! [Re: Diablo] #1028823
07/11/11 12:13 PM
07/11/11 12:13 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Diablo,that's a nice looking set-up.What kind of set up is it? Looks like it might be terminators but not sure.Would like to know a little more about it,but can understand if you must keep it secret to protect your edge on the competition.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Let me see your tunnel rams! [Re: MRMOPAR622] #1028824
07/11/11 02:11 PM
07/11/11 02:11 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
The intake is built by CFE. The throttle Bodies on top are Kingsler. They are very close to the Terminators but made by Kinsler. From what i've read a heard the air distribution is much better with the 4 intake throttle bodies compared to the one big toilet.
The 8 injectors in the Intake are for idle and lower rpm's once a pressure hits a certain point a poppet opens and the fuel starts injecting right behind the intakes valves. So kind of like direct port injection. This way the intake and heads are trying to flow as much air as possible with worrying about the alchy taking up to much space. And believe me this engine drinks A LOT of alchy. We will burn 3-4 gallons in one 300 foot pull.
This picture is a better shot of the front
Our other Ts engine has Terminators on it but only has the injectors in the intake.
Re: Let me see your tunnel rams! [Re: Diablo] #1028825
07/11/11 02:35 PM
07/11/11 02:35 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
426 hemi 2 1050 holley dom. carbs stock 6 pack/hemi lid 2 3" k/n filters
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Let me see your tunnel rams! [Re: toplescuda] #1028826
07/11/11 02:39 PM
07/11/11 02:39 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
differnt shot
1971 charger
Re: Let me see your tunnel rams! [Re: toplescuda] #1028827
07/11/11 03:21 PM
07/11/11 03:21 PM
iowa
wesw Offline
wesw  Offline
iowa
my car
598 ci predator
Re: Let me see your tunnel rams! [Re: wesw] #1028828
07/11/11 06:08 PM
07/11/11 06:08 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Here is couple from a few years ago.
Re: Let me see your tunnel rams! [Re: Biginchmopar] #1028829
07/11/11 06:15 PM
07/11/11 06:15 PM
Carson City, Nevada
Carson City, Nevada
Pic #2
Re: Let me see your tunnel rams! [Re: Biginchmopar] #1028830
07/11/11 06:17 PM
07/11/11 06:17 PM
Carson City, Nevada
Carson City, Nevada
Street car!
Re: Let me see your tunnel rams! [Re: HardcoreB] #1028831
07/11/11 06:26 PM
07/11/11 06:26 PM
Carson City, Nevada
Carson City, Nevada
I will play show and tell too, this one is collecting dust from other peoples projects.
Do you have any pictures of the completed plumbing of your water system. I have the same reverse flow plate and I was looking fo ideas on how to get it to the radiator.
Re: Let me see your tunnel rams! [Re: Biginchmopar] #1028832
07/11/11 06:52 PM
07/11/11 06:52 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: Let me see your tunnel rams! [Re: Biginchmopar] #1028833
07/11/11 10:17 PM
07/11/11 10:17 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I used Aeroquip FC598-12 hose. The adapter is 3/4NPT so I used an alloy adapter from male pipe to 3/4" barb then hose clamped the line. The rad.-end uses Aeroquip pushloc -12 AN. I welded a plate to the radiator that I pre-welded 2 (-12) male AN's onto...replacing the original 1 1/2" hose barb.
Re: Let me see your tunnel rams! [Re: HardcoreB] #1028834
07/11/11 10:40 PM
07/11/11 10:40 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
This as close to being on my car as mine is likely to get...
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Let me see your tunnel rams! [Re: HardcoreB] #1028835
07/12/11 12:25 PM
07/12/11 12:25 PM
Carson City, Nevada
Carson City, Nevada
Thanks! Got any pics you can post for me?
Re: Let me see your tunnel rams! [Re: Dragula] #1028836
07/13/11 01:36 AM
07/13/11 01:36 AM
Canada
CrAzYMoPaRGuY Offline
Canada
CrAzYMoPaRGuY
Re: Let me see your tunnel rams! [Re: CrAzYMoPaRGuY] #1028837
07/13/11 01:38 AM
07/13/11 01:38 AM
Canada
Canada
CrAzYMoPaRGuY
Re: Let me see your tunnel rams! [Re: CrAzYMoPaRGuY] #1028838
07/13/11 01:39 AM
07/13/11 01:39 AM
Canada
Canada
Many moons ago....
CrAzYMoPaRGuY
Re: Let me see your tunnel rams! [Re: CrAzYMoPaRGuY] #1028839
07/13/11 01:41 AM
07/13/11 01:41 AM
Canada
Canada
My work truck for years....
CrAzYMoPaRGuY
Re: Let me see your tunnel rams! [Re: CrAzYMoPaRGuY] #1028840
07/13/11 02:10 AM
07/13/11 02:10 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Saw one of those at Carlisle with a 6 pak top for only $650
Did you make the 2x4 top for yours? I was told they were only made for Super Stock with a choice of 6pak or single four. Supposed to be about the best TR for a 440 and it will fit in a 6pak scoop.
Kevin
Re: Let me see your tunnel rams! [Re: Twostick] #1028841
07/13/11 10:11 PM
07/13/11 10:11 PM
Canada
Canada
Mine was a converted 3x2bbl top.
It worked well, had tons of torque and great top end.
CrAzYMoPaRGuY
Re: Let me see your tunnel rams! [Re: CrAzYMoPaRGuY] #1028842
07/13/11 10:25 PM
07/13/11 10:25 PM
Page 2 of 4 1 2 3 4
