where to mount neg bat. cable alum head hemi?
#1028531
07/08/11 07:58 PM
07/08/11 07:58 PM
Posts: 8,848 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
ok i asked in q n a but no responce so ask you guys where the heck di ya mount the neg. battery cable on a hemi with alum heads?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: where to mount neg bat. cable alum head hemi?
[Re: mickm]
#1028534
07/08/11 10:42 PM
07/08/11 10:42 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
ok went back down and looked there is no bolt hole at all on the front of the driver head no plates so that wont work either didnt think alum would make a good ground??? intake,water pump and heads are alum.
[Re: Cab_Burge]
#1028537
07/08/11 11:59 PM
07/08/11 11:59 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I ground my neg. to the frame and run a ground from each aluminum head to the side of the aluminum block then to the frame again per MSD inst..
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1028538
07/09/11 12:48 AM
07/09/11 12:48 AM
Posts: 12,394 Taxes & Virus's R-US, NY
Dragula
This is the only way you want to do aluminum headed engine with a nasty ignition....Each head must be grounded....Otherwise the coil wire will arc to the head or anything close to it.
[Re: Dragula]
#1028539
07/09/11 12:56 AM
07/09/11 12:56 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
i will redo it but i needed to bump motor over to do the converter bolts so right now it to the top power stearing pump bolt
[Re: Hemi Allstate]
#1028542
07/10/11 11:15 PM
07/10/11 11:15 PM
Posts: 114 Crossville,TN
526ciduster
Crossville,TN
Run ground to front and attach it to bell housing or block and to each head and intake and frame. if battery is in trunk never ground to frame in back and front too. From hours of chasing down problems this is what worked for me.
Outlaw 10.5
526ci, F3R procharged tfx hemi, Big Stuff 3
PTP RACING
[Re: rowin4]
#1028544
07/10/11 11:40 PM
07/10/11 11:40 PM
526ciduster
Crossville,TN
static loop. and also any part that shifts with heat and expansion should have a groung by itself. using a frame by itself for ground is never a good idea. I dont want to get into pee pee match but this is coming from some of the fastest in the business that have experienced the problem that high output ignitions can provide through bad grounds.
Outlaw 10.5
PTP RACING
[Re: HEMIFRED]
#1028546
07/11/11 12:51 PM
07/11/11 12:51 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
ok guys the only reason i asked is cause MY heads do not have a lug or bolt hole to mount a battery cable to i was always under the impression that alum dont make as good of ground as steel i had to ground it on the power steer bracket wich does not look clean to me and i want to (and will) find a differnt spot to ground it as far as running a wire to each head??? does it not have 17bolts doing just that?? (alum head iron block)
[Re: toplescuda]
#1028547
07/11/11 12:56 PM
07/11/11 12:56 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
..motor on the left
[Re: John_Kunkel]
#1028549
07/11/11 01:20 PM
07/11/11 01:20 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
this is what iv been working on....angies 74challenger now with a 426 hemi lil sollid roller (600),alum rod,landy heads will get the tunnel ram back on it i just wanted to fire it up get timing where i wanted it then switch it over not sure how pic will show up as did with the phone
[Re: toplescuda]
#1028550
07/11/11 01:23 PM
07/11/11 01:23 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
to the head can also include using an intake or exhaust bolt.
home of the Sox and Martin Hemi Duster
