AB7FH ......... VACUME PUMP PICS #1028080
07/07/11 11:14 PM
07/07/11 11:14 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
hello rick
some pics for you
1.39 9.85 - 137 mph
Re: AB7FH ......... VACUME PUMP PICS [Re: Ari440] #1028081
07/07/11 11:15 PM
07/07/11 11:15 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
1.39 9.85 - 137 mph
Re: AB7FH ......... VACUME PUMP PICS [Re: Ari440] #1028082
07/07/11 11:17 PM
07/07/11 11:17 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
1.39 9.85 - 137 mph
Re: AB7FH ......... VACUME PUMP PICS [Re: Ari440] #1028083
07/07/11 11:23 PM
07/07/11 11:23 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Thanks Ari, I appreciate it.
I talked to Moroso today. They said the 3 vane enhanced pump doesn't come with a bracket, the 4 vane enhanced does. They told me to use this one with a motor plate:
But looking at where it mounts to the pump I don't see how it would work.
Is this the bracket you have?
http://www.summitracing.com/parts/MOR-63910/?rtype=10
I was looking at the different brackets and that one seemed to be the closest to what I see in your photo.
Re: AB7FH ......... VACUME PUMP PICS [Re: PolyDart] #1028084
07/07/11 11:25 PM
07/07/11 11:25 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
1.39 9.85 - 137 mph
Re: AB7FH ......... VACUME PUMP PICS [Re: Ari440] #1028085
07/07/11 11:29 PM
07/07/11 11:29 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
the second bracket you posted is what I have and using the ANDYFs motorplate and low mount altenater and bracket for it
1.39 9.85 - 137 mph
Re: AB7FH ......... VACUME PUMP PICS [Re: Ari440] #1028086
07/07/11 11:44 PM
07/07/11 11:44 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Thanks, I'm running the same motor plate and alt mount so that's what I'll order
Re: AB7FH ......... VACUME PUMP PICS [Re: PolyDart] #1028087
07/08/11 02:09 AM
07/08/11 02:09 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i bought the lower bracket to fit my 3 vane enhanced pump but found the pump doesn't have mounting holes.
so i've had to buy the top bracket.
Vacuum Pump Pics [Re: rebel] #1028088
07/13/11 08:30 PM
07/13/11 08:30 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Rebel, I ended up buying both and will return the unused bracket.
The new style bracket mounted very easily to my motor plate. Everything is hooked up, and I fired the motor today. It's pulling 6lbs at idle right now. I'll do a final adjustment at the track this weekend.
Ari, thanks for your help, who would have thought that they changed the mounting systems
Re: Vacuum Pump Pics [Re: PolyDart] #1028089
07/13/11 08:31 PM
07/13/11 08:31 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Re: Vacuum Pump Pics [Re: PolyDart] #1028090
07/13/11 08:31 PM
07/13/11 08:31 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Re: Vacuum Pump Pics [Re: PolyDart] #1028091
07/13/11 08:32 PM
07/13/11 08:32 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Re: Vacuum Pump Pics [Re: PolyDart] #1028092
07/13/11 08:33 PM
07/13/11 08:33 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
