front parking lights #1027225
07/06/11 11:46 AM
07/06/11 11:46 AM
missouri united states
V
vratman 69 Offline OP
V
replaced turn signal assembly and bulbs turn signals work parking lights work when you turn headlight switch on the parking lights go out turn signal still work with lights on parking lights dont any ideals?
Re: front parking lights [Re: vratman 69] #1027226
07/06/11 11:53 AM
07/06/11 11:53 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
1968? Normal.
Re: front parking lights [Re: buildanother] #1027227
07/06/11 12:18 PM
07/06/11 12:18 PM
V
V
yes its a 68 roadrunner
Re: front parking lights [Re: buildanother] #1027228
07/06/11 12:25 PM
07/06/11 12:25 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
1968? Normal.
What Dan said. That's the only difference that I could find in the under dash and headlight/parking light wiring harnesses between a '68 and '69 RR/GTX, that was one yellow wire from the dash headlight switch. Figure because the '68 has 4 side marker lights and the '69 has reflectors and no lights they needed to turn off the '68's parking lights when the headlights were on to minimize the draw so the alt could keep up at idle with all of the other things that might also be on
This flipped me out too when I first noticed it on my '68 rr, had to ask on here after spending an hour or so trying to figure it out
MikeR
