Page 2 of 3 1 2 3
Re: Launch RPMs.... [Re: JERICOGTX] #1027198
07/06/11 06:00 PM
07/06/11 06:00 PM
NC
barracuda man Offline
NC
3800 rpm
Re: Launch RPMs.... [Re: barracuda man] #1027199
07/06/11 08:10 PM
07/06/11 08:10 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
3500 on the brake..if the track will hold it...2800 max on the footbrake or it will push the lites.
The little old lady from Pasadena is back!
Re: Launch RPMs.... [Re: tboomer] #1027200
07/06/11 08:50 PM
07/06/11 08:50 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
3600 9.5" 6000 converter and glide....
Re: Launch RPMs.... [Re: 540dust] #1027201
07/06/11 09:12 PM
07/06/11 09:12 PM
Anoka County, MN
Leigh Online content
Leigh  Online Content
Anoka County, MN
I hold the wheel with my left hand at 7:00, with my arm close to my body. This allows me to be relaxed, and not interfere with my button hand/arm. Also, line up in the burnout box, looking at the stripe. Burn to within' 6'-10' feet of prestage, and don't back up. Oh, forgot, 3,000. For a bracket car, any more is just parts $$$ down the drain. Let the converter flash take care of the rest. If it doesn't work, get another converter, or look for engine related issues.
Re: Launch RPMs.... [Re: Leigh] #1027202
07/06/11 10:31 PM
07/06/11 10:31 PM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
In my cuda with a TF trans and tb running 9.80s i left at 3k with 20lbs in the front tires to stay green. In my camaro I left anywhere from 2850 with a trigger trans brake to 5200 at a alt factor track with a terminator trans brake. in my dart i was leaving at 4600 with a terminator button and a converter going away.
Re: Launch RPMs.... [Re: ChrisJohnston669] #1027203
07/06/11 10:38 PM
07/06/11 10:38 PM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
3600 most of the time if the track is greasy 3400.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: Launch RPMs.... [Re: Leigh] #1027204
07/06/11 11:00 PM
07/06/11 11:00 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
Some converters will flash and pull the car higher with lower stall if the converter is around 5,400 to 6,500 i started out with 3,600 and now i stall at 4,600 and it went up the same and my converter is a 5,000 stall and it could be the torque of the engine some times will pull the car or more air in slick or put more air in the slicks could help and it could just be the track but you know your car better then any body good luck
Re: Launch RPMs.... [Re: steeldust] #1027205
07/06/11 11:24 PM
07/06/11 11:24 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Ted, the tape stripe at the top of the wheel is a good idea to ensure you are pointed straight ...
I always hold my left hand on the wheel between 7 - 8 oclock where my wrist is comfortable and my arm is resting on the roll cage door bar.
This makes sure i don't steer the car when the wheels come down. When i used to hold the top, i sometimes pulled off center when in the air...
Good luck,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Launch RPMs.... [Re: MR_P_BODY] #1027206
07/07/11 12:21 AM
07/07/11 12:21 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Like been said already very combination dependent. When I run S/ST I am at 3800, all out anywhere from 5800-6600 depending on tbhe track.
Re: Launch RPMs.... [Re: Al_Alguire] #1027207
07/07/11 07:14 AM
07/07/11 07:14 AM
tboomer Offline OP
tboomer  Offline OP
LOts of good stuff here...Thanks everyone! Now...a question for the guys leaving at 3000-3600. Are you using a chip in a two-step or leaving off the tach? The goal here is to be consistant!!
Re: Launch RPMs.... [Re: tboomer] #1027208
07/07/11 07:30 AM
07/07/11 07:30 AM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
I have always left on the brake at 5500 rpm and now I picked up some better 60 feet going down to 3500 rpm.
You should move forward and not up in the sky
And put an onboard camara in the car, I did and it was fun to see what I did in the heat of the battle.
And yes I use the 2 step.
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Launch RPMs.... [Re: tboomer] #1027209
07/07/11 07:39 AM
07/07/11 07:39 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Two step.
Re: Launch RPMs.... [Re: tboomer] #1027210
07/07/11 08:05 AM
07/07/11 08:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If I'm running 10.0 class I leave at 3600 on the chip
and shift at 5600 with my mech throttle stop at 1/3
pedal
Re: Launch RPMs.... [Re: tboomer] #1027211
07/07/11 08:21 AM
07/07/11 08:21 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
3400 on a 2 step, full tree
"Just a Bracket car dressed up like a streetcar"
Re: Launch RPMs.... [Re: Just-a-dart] #1027212
07/07/11 09:36 AM
07/07/11 09:36 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
I talked to a old guy at Turbo Action Convertor years ago. I told him what the combo was and what I was doing with the car as in bracket style racing.Thats all we had for racing back then. I thought I needed a 5800 stall convertor (mostly for the wow factor). Well he asked me one question. How thick was my wallet? I had a very small budgit so from his recommendation I had a new 4800 converter. I been racing for awhile and the car is deadly and very little breakage. I leave at 3800 and the car will flash the converter at 4800. The 60' times are 1.42. Tested it couple times at 4600 and all the differance was .002 off the 60' time. Alot harder hit and I could see breaking things at that rpm.
What I see from the vidio is you turn the wheel at the launch. The car is not wheel standing its poping the wheels up mabe 6". If it was me I would launch at 800 below the converter stall and work on the car from there. I bet money you will end up faster.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Launch RPMs.... [Re: slippery440] #1027213
07/08/11 08:03 AM
07/08/11 08:03 AM
tboomer Offline OP
tboomer  Offline OP
OK...Here is what we are going to do. The lowest rpm chip I could find is 3400. So that will be a start. I will also try to change my driving technique by resting my left arm on the bar with my hand in the 7:00 o'clock position. All of the years leaving off the footbrake I had one hand on the shifter and the other at the 10:00 o'clock position. Thanks for all of the suggestions,guys!!
Re: Launch RPMs.... [Re: gregsdart] #1027214
07/08/11 12:58 PM
07/08/11 12:58 PM
iowa
bad1970dust Offline
"Hollywood"
bad1970dust  Offline
"Hollywood"
iowa
It looks to me like a chassis problem causing at least some of the move to the left. Focus if you can on your steering wheel on launch. If you see that you are not turning the wheel a lot, then something is unloading the left rear tire a couple of feet after the hit. Short shocks? Wrong preload?
As far as rpm, I would start at 3,000 rpm and see where things are. 3,000 should give you a consistent leave, and let you know what you need for proper chassis reaction time.
watching the car in person it leaves straight turns hard once touches down drove the car 7 passes never went right or left. ted i got plenty of msd chips if you want change it.their in the trailer. for the weekend.I would pratace on not watching the other car on my launch,
Re: Launch RPMs.... [Re: JERICOGTX] #1027215
07/08/11 01:36 PM
07/08/11 01:36 PM
CheddarHead till October
weedlayer Offline
weedlayer  Offline
I have been thinking about going down a bit till I can get a handle on this thing...What do ya think? Ted
I knew you wore a skirt.
Re: Launch RPMs.... [Re: weedlayer] #1027216
07/08/11 07:36 PM
07/08/11 07:36 PM
tboomer Offline OP
tboomer  Offline OP
Says the guy who has an inch of dust on his car out in the garage! How ya doin,Ray?
Re: Launch RPMs.... [Re: tboomer] #1027217
07/08/11 08:45 PM
07/08/11 08:45 PM
Guitar Jones Offline
Depends for me too. 3000 when using the brake and no box. It will go .000 like that. If I'm slow that day I'll bump it up a little. I use a two step with chips. If it's a .4 pro tree then it's no chip and fully on the 4200 converter. It will go .012 like that but I have to be really on.
Are you allowed an air shifter? I love mine, I let go of the button and put both hands right back on the wheel, that way I don't turn it when it's in the air.
"Come get your wife"
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion.
Page 2 of 3 1 2 3
