Re: Launch RPMs....
[Re: tboomer]
#1027180
07/06/11 11:38 AM
07/06/11 11:38 AM
Posts: 52,972 Romeo MI
MR_P_BODY
That will change the reaction time Ted... so what do you need to do with the RT... higher RPM and you come off the line harder(unless you spin)... I dont use a launch chip... I go right up on the stall of the conv(5600 in my case).... keep playing with it till you find the happy point
Re: Launch RPMs....
[Re: MR_P_BODY]
#1027182
07/06/11 11:43 AM
07/06/11 11:43 AM
Posts: 1,288 Oregon
sg66mopar
Bracket racing I'll let mine stall at aroung 4600 on the stop.
Super Gas racing it's all in at around 6500.
Like Mr. P said, your RT will change (a lot) so you need to find the point you like then leave it alone.
Re: Launch RPMs....
[Re: sg66mopar]
#1027183
07/06/11 11:50 AM
07/06/11 11:50 AM
Posts: 25,986 United Socialist States of Ame...
tboomer
I think my biggest problem is when the car comes up into the air,is that I am jerking the steering wheel to the left...Jimmy says I should tape the steering wheel center...It makes a neat pic with the wheels up but tough to control!
Re: Launch RPMs....
[Re: tboomer]
#1027185
07/06/11 12:05 PM
07/06/11 12:05 PM
MR_P_BODY
Your turning the wheel... it didnt make a move till it came back down... I assume you use your left hand on the wheel and dont rest your arm/brace it and when you launch your arm pulls the wheel some(to the left)... I brace my left arm on the door/window sill
Re: Launch RPMs....
[Re: tboomer]
#1027187
07/06/11 12:10 PM
07/06/11 12:10 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
It looks to me like a chassis problem causing at least some of the move to the left. Focus if you can on your steering wheel on launch. If you see that you are not turning the wheel a lot, then something is unloading the left rear tire a couple of feet after the hit. Short shocks? Wrong preload? As far as rpm, I would start at 3,000 rpm and see where things are. 3,000 should give you a consistent leave, and let you know what you need for proper chassis reaction time.
Re: Launch RPMs....
[Re: tboomer]
#1027190
07/06/11 12:40 PM
07/06/11 12:40 PM
MR_P_BODY
Thanks,Greg! I need some different ideas...One thing I should say is that I have never scaled the car yet...
Ted I was looking at the vid again to see if you had a lot of toe change... as you know the flex in the car lifts the left front more than the right so the right tire sets down first which for a brief second has the control of the steering but the tire on your car doesnt have anywhere near enough angle to cause the issue so I'm back to you are turning the wheel
Re: Launch RPMs....
[Re: Dunnuck Racing]
#1027191
07/06/11 12:50 PM
07/06/11 12:50 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
On launch if you are not lined up straight or if you are a little out of the groove it will do that. It looked like you were lined up right,that's just something to check next time at the track. If I were were you before going back to the track I would switch the rear tires and see if it starts pulling to the right.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
Re: Launch RPMs....
[Re: tboomer]
#1027197
07/06/11 06:58 PM
07/06/11 06:58 PM
Posts: 10,043 MN
JERICOGTX
MN
I have been thinking about going down a bit till I can get a handle on this thing...What do ya think? Ted
I knew you wore a skirt.
