440 cam choice #1027057
07/05/11 11:48 PM
07/05/11 11:48 PM
minnesota
P
president61 Offline OP
P
minnesota
a friend of mine has a 68 GTX with a 440. its a newer police pursuit motor(cast crank) with 915 heads. it still has the bone stock camshaft in it. he wants a bigger cam to increase performance. still has stock intake and exhaust manifolds, and 750 edelbrock carb. I told him the factory 68 440 magnum cam would be a good choice. What are your thoughts? thanks. He does drive the car quite a bit.
Re: 440 cam choice [Re: president61] #1027058
07/06/11 01:35 AM
07/06/11 01:35 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
i used a erson high flow cam it had 292 duration and low lift 466 i think came off of a 440 6pac car ran good on mine.
Re: 440 cam choice [Re: moparsquid] #1027059
07/06/11 11:45 PM
07/06/11 11:45 PM
minnesota
P
P
minnesota
anybody else??
Re: 440 cam choice [Re: president61] #1027060
07/07/11 12:30 AM
07/07/11 12:30 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I'd start with a set of headers and an intake before I went to the camshaft.
Re: 440 cam choice [Re: StealthWedge67] #1027061
07/07/11 01:51 AM
07/07/11 01:51 AM
PA
jc070680 Offline
jc070680  Offline
PA
I agree... you will base your cam on your gear ratio, stall and what intake and carb setup you WILL have.. Unless you plan on keeping everything else stock...
Re: 440 cam choice [Re: StealthWedge67] #1027062
07/07/11 04:33 AM
07/07/11 04:33 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 440 cam choice [Re: jc070680] #1027063
07/08/11 12:04 AM
07/08/11 12:04 AM
minnesota
P
P
minnesota
he does want to keep everything else stock, thats why i thought of a stock 440 magnum cam.
Re: 440 cam choice [Re: president61] #1027064
07/08/11 01:13 AM
07/08/11 01:13 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Then in that case, yes you're right, the stock HP cam would be a good fit. Another decent choice would be the lunati voodoo 60302, it'll be similar in spec to the stock hp cam.
Re: 440 cam choice [Re: DaytonaTurbo] #1027065
07/08/11 01:33 AM
07/08/11 01:33 AM
PA
jc070680 Offline
jc070680  Offline
PA
The lunati would be my choice, but either would be a good choice.. Good luck!!
Re: 440 cam choice [Re: president61] #1027066
07/08/11 09:36 AM
07/08/11 09:36 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
My almost bone stock 67 GTX went 13.82 (14.20 w/ stock cam) by using a Summit 488 cam, CH4B intake and the tiny stock carb. On street radials, thru the logs and complete exhaust. Automatic w/ 3.55's. Hi-Po manis are fine if you stick with a mild cam. I'd also consider swaping the intake out for a CH4B they look almost stock. If you grind the Eddy offf and paint it 90% of the donkeys wouldn't even know it wasn't stock.
Coming soon!!!!
Re: 440 cam choice [Re: president61] #1027067
07/08/11 11:03 AM
07/08/11 11:03 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: 440 cam choice [Re: DaytonaTurbo] #1027068
07/08/11 11:15 AM
07/08/11 11:15 AM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I chose the voodoo 60302 after a lot of debate on which one to run. I could not be happier. 67 915 headed 440, performer intake with a 850 cfm TQ and manifolds. I have a solid 16 In. of vacuum at idle and is a brute from idle right up to 5500 rpm. No problems with my power brakes at all.
Re: 440 cam choice [Re: T2R9] #1027069
07/09/11 11:40 PM
07/09/11 11:40 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
My 68 440 has the Voodoo 604. 513/533 Holley street dominator intake and an 850 TQ with 3000 stall 3.55 rears. Stock manifolds with hemi style mufflers. 15 inches of vac at idle and it idles smooth at 850. Cam is not lumpy at all. Idle's like a stock 68 HP motor. Makes great power. Pulls hard to 6000. I love it.
Re: 440 cam choice [Re: Dougsmopars] #1027070
07/10/11 01:21 AM
07/10/11 01:21 AM
Manitoba, Canada
Manitoba, Canada
Yeah but it sounds like he's got a low-cr 70's 440. I put a 60303 in one and it was okay, but I had 3.55 gears and headers. His combo sounds even more tame so I bet he'd want to go a lil milder.
Re: 440 cam choice [Re: DaytonaTurbo] #1027071
07/10/11 11:01 AM
07/10/11 11:01 AM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
The Lunati 302 is aimed at this type of application
Steve
