removing door mirror from backing? #1026274
07/05/11 02:00 AM
07/05/11 02:00 AM
MI
AfterHoursResto Offline OP
MI
What is a good way to remove the mirror from the backing plate? Trying to replace my door mirror without getting 7 years of bad luck.
Roman Sobilo
Re: removing door mirror from backing? [Re: AfterHoursResto] #1026275
07/05/11 11:05 AM
07/05/11 11:05 AM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
I used a hammer. Only one more year of bad luck to go.
You can lead a gift horse to water, but you
can't look in his mouth.
Re: removing door mirror from backing? [Re: ChickMaggot] #1026276
07/05/11 07:13 PM
07/05/11 07:13 PM
indiana
generallee6901 Offline
indiana
Boil it in water.should fall right off.
Re: removing door mirror from backing? [Re: generallee6901] #1026277
07/05/11 10:45 PM
07/05/11 10:45 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
hair dryer or heat gun
logan426
