408 stroker question #1025473
07/03/11 11:31 PM
07/03/11 11:31 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
On the stroker kits for the 360 engine, the rods are to be 6.125 inches long. the factory are 6.123 . does the .002 really make a difference ? Can you use the factory rod , why or why not?
Who makes a kit, how much, how well does a 408 run
Re: 408 stroker question [Re: moparmikethree] #1025474
07/04/11 12:01 AM
07/04/11 12:01 AM
(1) .002-no diff (2) yes but w the plethora of good/cheap aftermarket rods avail nowadays it's a smart plan to go aftermarket (3) not sure (4) dont know (5) reportedly like a scalded cat from all who have went from a 360 to a 408 (360)/416 (340)
Re: 408 stroker question [Re: moparmikethree] #1025475
07/04/11 12:57 PM
07/04/11 12:57 PM
SoCal
Brian Hafliger Offline
SoCal
Here's a mild stroker I put in my duster to see how it would run:
http://img192.imageshack.us/img192/6981/irwindalevids002.mp4
http://www.carcraft.com/techarticles/ccrp_1006_small_block_mopar_stroker_dyno_test/index.html
Brian Hafliger
