type f and dextron 3 #102503
08/10/08 05:39 PM
08/10/08 05:39 PM
New Zealand
solidcam Offline OP
solidcam  Offline OP
New Zealand
I know this topic has been raised before and probably causes differing opinions.My question is if I wanted switch from 3 to f what is involved in getting all the 3 out,(and is it necessary to do so)other than obvious draining of the pan.Trans in question is a 727,deep pan,modified clutches,reverse pattern manual valve body non front band apply.Horsepower level 600.
What are the pro's and con's of this switch if any?
Re: type f and dextron 3 [Re: solidcam] #102504
08/10/08 06:51 PM
08/10/08 06:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There is no need to purge the old fluid before changing fluid types, in fact you can mix them in any desired proportion with no ill effects.
