Re: Putting motor in 73 Roadrunner
[Re: 73rrak]
#1025005
07/04/11 10:11 AM
07/04/11 10:11 AM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
The headers will not fit with the engine installed,it needs to be jacked up and lowered sliding the headers in as it drops. Also you will need to trim some of the sheet metal on the passenger side for the header to fit since it was originally a SB car. If it was a factory BB car the engine pan on the RH side has a large opening and uses a large Matt to cover that opening..... Keep in mind you will need to roll the engine side to side. So take the motor mount bolts out and I would remove the trans mount too. You should be able to fit them in then... Good Luck!
