Page 3 of 3 1 2 3
Re: What to do with an LA 318? [Re: Dean_Kuzluzski] #1024890
10/01/11 01:28 PM
10/01/11 01:28 PM
the KB hypereutectics are the ONLY budget oriented offerings out there. And w/o them you're limited to running the 85 era "swirl-port" that have small valves & ports.
Dean for my information could you expound on that a bit more? I have one (318) & some mags and some 302's just havent got serious about a plan yet (mileage build)
Re: What to do with an LA 318? [Re: RapidRobert] #1024891
10/01/11 01:50 PM
10/01/11 01:50 PM
Holland MI Ottawa
2
2boltmain Online content
2boltmain  Online Content
Holland MI Ottawa
I thought the single plane 2bbl intake was a 273 only item. Maybe 318s came with them or its a transplant. Not worth a whole lot- kind of like a 305 chevy motor- Lots and lots abound.
Keep old mopars alive.
Re: What to do with an LA 318? [Re: 2boltmain] #1024892
10/01/11 01:58 PM
10/01/11 01:58 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
The 318 in my 72 Duster had the single plane on it.
Re: What to do with an LA 318? [Re: 2boltmain] #1024893
10/01/11 02:37 PM
10/01/11 02:37 PM
I thought the single plane 2bbl intake was a 273 only item. Not worth a whole lot
(1) That may be correct (2) yes only to a circle burner such as myself where an iron 2bbl is required (class rules) and the single plane iron 2bbl intakes flow a whole lot better than the later dual plane 2 bbl ones
Re: What to do with an LA 318? [Re: RapidRobert] #1024894
10/03/11 12:28 PM
10/03/11 12:28 PM
dogdays Offline
dogdays  Offline
So, RR, it flows better than a late carb or TBI intake?
Got one on my free '71 donor truck.
When the 273 first came out the engineers were trying to get it to fit under a hood, maybe Valiant or Dart. They chose the single-plane because it was lower, believe it or not. They were quite proud of getting it to work as well as a dual-plane. This is from an article on the "new 273" published way back when.
R.
Re: What to do with an LA 318? [Re: dogdays] #1024895
10/03/11 01:45 PM
10/03/11 01:45 PM
So, RR, it flows better than a late carb or TBI intake? Got one on my free '71 donor truck.
definitely better than the dual plane ones plus open up the 2 flange holes into a common opening. The TBI, is that the "barrell" intake? Wanted to check one out but I think they're alum which is not allowed that and the weird barrell shape may spook the tech guys!
Re: What to do with an LA 318? [Re: RapidRobert] #1024896
10/03/11 03:53 PM
10/03/11 03:53 PM
Columbus Ohio
mopfried Offline
mopfried  Offline
Columbus Ohio
THE tbi intakes were on the pre injection barrel intakes. My old '89 dodge W100 was a Teen TBI... Electric two barrel carb!
Re: What to do with an LA 318? [Re: mopfried] #1024897
10/03/11 06:56 PM
10/03/11 06:56 PM
dogdays Offline
dogdays  Offline
Yeah, that's what I was talking about. The TBI came before the MPFI. On some chevy engines the late TBI intakes are better than earlier 2-barrel intakes.
R.
Re: What to do with an LA 318? [Re: dogdays] #1024898
10/06/11 07:55 AM
10/06/11 07:55 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
NOTE TO READERS: I can be a real cheapass, so no moans from the purists.
Here's the absolutely least cost way to go. Assuming it really is a 30K engine, get the engine indoors and take it apart. I'm betting you will find some surface rust on one or two cylinders. This'll probably clean up quickly. Even if you had so much rust that you had to bore one or two cylinders and put oversize pistons in that one or two (which has been done before and WILL work okay), the other 6 or 7 don't even need to be pulled, except to ready the block for machining. But I have started many engines that have sat for years under hoods without more than checking the oil and getting the fuel system up to snuff and haven't had a problem with them sealing. So put new rings in a 30K engine? No way unless it's blowing smoke. Bearings? Don't mess with success. Run'em and forget about'em.
I'd spend some time looking at the timing chain. If it is a silent link chain with a gear with nylon teeth change it. Don't want any gremlins lurking! While you're at it swap cams for a small low-cost cam with less than 210 degrees duration at 0.050 lift and 110 lobe separation. Even a stock 360 cam will be better than the puny cam in there now. But you don't want to have to change valve springs so keep lifts at 0.440 or less. BTW, I do NOT like the Summit cams, They work okay but with a 114 LSA they lack midrange and close the intake valve too late. The Comp HE 252 would be a good choice if you could find it. There are a couple of Speed Pro cams that would also fit well.
Use the heads you have but put new valve stem seals on while you have the chance and check the seats and guides to be sure you don't have abnormal wear.
For induction I'd use a late 360 TQ intake or a Performer if you can find one cheap. Any smallblock 4-barrel intake will work. If you're into carbs then a Carter AVS would be pretty nice, the air valve secondary keeps it from being too big. I'm running a Holley 1850 600cfm carb and it works well on my 318. If you have access to Thermoquads or Quadrajets and can work on them yorself they'd also be good.
I'd concentrate on finding a '67 or '68 Valiant or Dart or even one older than that. They're pretty light.
Transmissions I'd use would be the A-998 or A-999 or the 500 overdrive. No sense going to a 727 at this power level. Combine the 904 types with a 2.76 gear for high speed running.
I'd spend money on headers because they beef up the torque curve under the peak.
If I was closer I'd drive over and haul it away. A 30K engine has some value left in it, even if it is a lowly 318. Just don't replace ANY MORE than you have to.
R.
this is what I'd probably do...if the bores look a little ooky, but not bad, maybe hone and toss some new cast rings in it....if you take it to a machine shop to get it honed, before you tear it apart, measure how far down in the hole the pistons are, and have the block decked to get compression up, try aim for the pistons ~.012-.015 in the hole, so you can use the Mr. Gaasket .028" thick gaskets to get ~.040 quench with closed chambered heads.
heads, use what you got, I'd probably go for a lunati voodoo 60400 or 60401 cam with comp #901 springs. if you want a real hard charger, swap the heads for some junkyard magnums redrilled to LA bolt pattern, and some hughes #1110 springs and chrysler 2.2L/2.5L retainers, or some junkyard '94-up GM 3.1/3.4L valve springs and retainers.
intake, any 4bbl, carb, probbaly an eddy 1406, t-quad or q-jet
2017 Grand Cherokee Overland
Re: What to do with an LA 318? [Re: tripleblackcuda] #1024899
10/06/11 03:31 PM
10/06/11 03:31 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Don't junk the carb or the adapter, sell them to me!
Ditto, im 2nd in line! pour some gas in it and starts it. D@mn the cylinder rust, itll come out! running 318's with 2bbl intakes are 100 bucks on craigs....You could probably part it for more. manifolds, crank, carb, covers, AL water pump, etc.
Re: What to do with an LA 318? [Re: RapidRobert] #1024900
10/07/11 12:36 AM
10/07/11 12:36 AM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
They make killer budget street rod engines!!
Sadly the build cost is identical to a 360 (actually cheaper when you figure in piston choices!). You get a little more with a 360 of course but don't dismiss a 318. They can be a fun engine with the right bolt on's.
I'd never scrap one unless it was just junk. I have a soft spot for them. 318's have been reliable as a stone for me
600 carb,decent dual plane intake, headers and 340 spec cam will spin a tire with ease. Super fun a body setup!
Re: What to do with an LA 318? [Re: MuuMuu101] #1024901
10/07/11 04:30 AM
10/07/11 04:30 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
So when I bought my Darts 2 years ago I got this 318 as a part of the deal. I never really thought anything of it but now I am just curious what I could put it in. But first, just for background information, this thing has been sitting outside, uncovered since I got it. It is supposedly an all stock 70 or 71 318 out of a Barracuda and only had about 30k miles on it and was running when pulled. Approximately how much would it cost to rebuild this on a budget (not necessarily looking for super high power)? What could/should I do with this? I was thinking of finding some lightweight car and putting it in there with an auto for a little cruiser or something. Ideas/Thoughts? Picture was taken in November and I don't have access to it because it is at my mechanics. Thank you!
That thing actually looks very clean for an original engine. It looks like a 30K engine. Outside for 2 years in a state that doesn't have rain... i bet it'd fire right up and run fine forever. If you have a car drop it in and go through it as you see fit. Down the road you can do the Magnum top-end swap with heads and an RPM, add a cam, headers, whatever.
I've thrown away a few good engines that weren't 'cool'... and now i wish i had one. The Challenger needs SOMETHING to move it for now, and i wouldn't scoff at a 318. It wont make the power a nice 383-4 would, but it'd still move my light stick car and get decent mileage.
If you're not going to use it right now, keep it around, but drag it inside and cover it. You never know when it may come in handy. Hard to find decent, early low-mile engines.
Re: What to do with an LA 318? [Re: MuuMuu101] #1024902
06/28/12 09:56 PM
06/28/12 09:56 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
Don't think I have forgotten this thread. I should be heading to my mechanics Saturday morning for servicing the Jaguar and if the 318 is still there, I plan on taking some pictures. I haven't been there since my accident in my Stealth January 2011. Are there any numbers or codes on this thing I should take. I wonder how the CA weather has treated it since it has been sitting out for about 3.5 years. I still don't know what to do with it since it doesn't seem like I am going to have a project car for a long while now and since it has been sitting out way too long.
Re: What to do with an LA 318? [Re: MuuMuu101] #1024903
06/30/12 01:41 PM
06/30/12 01:41 PM
SoCal
SoCal
So, just as I figured, the engine was long gone.
Page 3 of 3 1 2 3
