Page 1 of 3 1 2 3
What to do with an LA 318? #1024850
07/02/11 09:32 PM
07/02/11 09:32 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
So when I bought my Darts 2 years ago I got this 318 as a part of the deal. I never really thought anything of it but now I am just curious what I could put it in. But first, just for background information, this thing has been sitting outside, uncovered since I got it. It is supposedly an all stock 70 or 71 318 out of a Barracuda and only had about 30k miles on it and was running when pulled. Approximately how much would it cost to rebuild this on a budget (not necessarily looking for super high power)? What could/should I do with this? I was thinking of finding some lightweight car and putting it in there with an auto for a little cruiser or something. Ideas/Thoughts? Picture was taken in November and I don't have access to it because it is at my mechanics. Thank you!
Re: What to do with an LA 318? [Re: MuuMuu101] #1024851
07/02/11 09:48 PM
07/02/11 09:48 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it isn't rusted solid then a base rebuild will run about $2000 parts and machine shop costs.
Re: What to do with an LA 318? [Re: stumpy] #1024852
07/02/11 09:51 PM
07/02/11 09:51 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
What is the partial VIN on the passenger side?
Re: What to do with an LA 318? [Re: Alaskan_TA] #1024853
07/02/11 09:55 PM
07/02/11 09:55 PM
SoCal
SoCal
I am honestly not sure. I don't have access to it. I will take more pictures and get more information when I go to my mechanics next time.
Re: What to do with an LA 318? [Re: MuuMuu101] #1024854
07/02/11 10:49 PM
07/02/11 10:49 PM
scratchnfotraction Offline
is that a 4-v carb on an 2-v to 4-v adaptor on the early 2-v intake?
I have done that before on an engine.
a tear down and looky see with a mic/feeler gauge is in oreder to decide if its a good build on the cheap or will need other hard parts and rebuild,re-ring IMHO
it is the sitting out side for a long while ?
it is kinda like a used 727,looks good on the floor while it is for sale...but does it work after you chanced it like the uesd parts lotto
good luck
Re: What to do with an LA 318? [Re: scratchnfotraction] #1024855
07/03/11 02:23 AM
07/03/11 02:23 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Considering a good, running used magnum or LA 318 can be had at the local u-pull yard for $200 w/ a 90 day warranty, I would probably just sell your 318 for the price of scrap if it's been sitting out getting rained on, etc.
Re: What to do with an LA 318? [Re: DaytonaTurbo] #1024856
07/03/11 02:43 AM
07/03/11 02:43 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
and take that cast iron bathtub too. who knows, you might get enough money for a case of beer, and a pack of smokes!!!
[Edited by Moparts - Family Friendly Site - Keep it clean]?!?!?! how did i become a sheep shagger? oh, the humanity!!!
Re: What to do with an LA 318? [Re: scratchnfotraction] #1024857
07/03/11 03:40 AM
07/03/11 03:40 AM
SoCal
SoCal
good luck
It's actually just a Holley two-barrel carb on the stock intake manifold. It has been sitting for a while now. It may not rain much in CA, but I think it would be enough rain to possibly do some damage. Idk, I figured rebuilding this would be better than buying a new one.
I was just thinking, that if I have to drive in traffic in the future (I know, I know, I have been blabbing about this a lot), that I could possibly hook it to a 904, 727, or a 518 (if they are compatible, I'm not sure) with an Overdrive and put it in a light-weight, pre-76 car (whatever pops up, not necessarily a mopar) and drive it as a daily driver. Just a thought.
Re: What to do with an LA 318? [Re: MuuMuu101] #1024858
07/03/11 03:58 AM
07/03/11 03:58 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Stroke it
Re: What to do with an LA 318? [Re: JoesMopar] #1024859
07/03/11 04:01 AM
07/03/11 04:01 AM
SoCal
SoCal
Stroke it
To a like 390 or something? I think I saw a kit for sale today for a little less than $2k not including tax and shipping.
Re: What to do with an LA 318? [Re: DaytonaTurbo] #1024860
07/03/11 09:47 AM
07/03/11 09:47 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
unless you are using this as your rebuild learning experience. the cost of rebuilding an unknown engine thats been sitting outside uncovered will keep your wallet empty.
Re: What to do with an LA 318? [Re: mikemee1331] #1024861
07/03/11 10:24 AM
07/03/11 10:24 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
build something different. weld up some steel tube, bolt a 727 behind it, and an 8.25 axle, and have a rolling chassis for cheap. then drop some sort of cool custom body on it. like a coffin, or an outhouse, or....
otherwise, as common as 318s are, I don't think it's worth anything. I hate to say that because it is a 1970s original, and worth something to the right guy (numbers motor, date coded for the right car on a concours restoration, etc.) finding that one guy will be next to impossible, and anyone can take a magnum 318 or even a magnum 360, add a few hundred bucks in performance upgrades, and have a nearly 400 hp engine for about a grand out of the junkyard...and since it was originally an EFI motor, even with 100K miles on it, it'll run like a top for years to come.
**Photobucket sucks**
Re: What to do with an LA 318? [Re: MuuMuu101] #1024862
07/03/11 11:14 AM
07/03/11 11:14 AM
Champion City
The Sphinx Offline
The Sphinx  Offline
Champion City
I recently ran into this situation. I had a low mile 68 casting 318. I just pulled it apart and checked the bores, and replaced the rings and bearings. I replaced the cam with a 340 spec cam i bought here and used a spread bore intake I bought used also from this site. I have less than $250 tied up into it. It's not going to be a powerhouse by any means but a good dependable engine. Then again a pair of cheap e-bay turbos may find their way onto it.
Re: What to do with an LA 318? [Re: The Sphinx] #1024863
07/03/11 11:55 AM
07/03/11 11:55 AM
USA
CrAlt Offline
CrAlt  Offline
USA
You already ruined any value that engine had by leaving it out side.
I'ed brake it down and see if it needs any machine work. If it does then scrap it. If not then do a cheapo rering/bearings (if needed) and store it in a dry place as a back up engine.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: What to do with an LA 318? [Re: CrAlt] #1024864
07/03/11 01:21 PM
07/03/11 01:21 PM
SoCal
SoCal
I think a mopar guy (he is not from here but he loved demons and was from Utah) back in November told me that the engine may only be worth around $50 or so since it's condition is unknown and all I have is information by word of mouth.
It would be cool to make a little kit car out of it or my own daily driver but how would you get a title for something like that?
Re: What to do with an LA 318? [Re: MuuMuu101] #1024865
07/03/11 02:11 PM
07/03/11 02:11 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
you are easily side-tracked aren't you?
Re: What to do with an LA 318? [Re: mikemee1331] #1024866
07/03/11 02:36 PM
07/03/11 02:36 PM
SoCal
SoCal
Not at all. I just analyze and elaborate on an idea when it comes up. And it is not really side-tracking from the thread because I am still trying to figure out what to do with this engine and using it in a little buggy or kit car kind of deal would be something I could do with it.
Re: What to do with an LA 318? [Re: MuuMuu101] #1024867
07/03/11 02:44 PM
07/03/11 02:44 PM
USA
CrAlt Offline
CrAlt  Offline
USA
Depends on the state.. im gona have to deal with this issue when my T-bucket is done.
http://www.semasan.com/images/pdf/california.pdf
http://www.semasan.com/main/main.aspx?id=62292
Re: What to do with an LA 318? [Re: CrAlt] #1024868
07/03/11 03:08 PM
07/03/11 03:08 PM
SoCal
SoCal
That is very cool. I will keep these websites in mind
Re: What to do with an LA 318? [Re: MuuMuu101] #1024869
07/03/11 07:16 PM
07/03/11 07:16 PM
Sturgis S.D.
tripleblackcuda Offline
Sturgis S.D.
Don't junk the carb or the adapter, sell them to me!
Page 1 of 3 1 2 3
