'68 GTX quarter panel emblem holes... HELP!! #1024778
07/02/11 08:21 PM
07/02/11 08:21 PM
south central nebraska
GI Moparman Offline OP
I am building a GTX tribute out of my '68 Sport Satelite Convertible, I got the quarter panel work all done but now I need to drill the holes for the "GTX" emblems. Does anyone have measurements on laying these holes out?? Pics would help alot too! Also, any pics on how well the quarter panel extensions fit the car, mine seem to fit pretty crappy and that area is untouched as far a I know.
Re: '68 GTX quarter panel emblem holes... HELP!! [Re: GI Moparman] #1024779
07/04/11 12:12 AM
07/04/11 12:12 AM
Anyone? Im sure im not the first person to run into this problem!
Re: '68 GTX quarter panel emblem holes... HELP!! [Re: GI Moparman] #1024780
07/04/11 01:16 AM
07/04/11 01:16 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Here's the left side:
That's 11 1/8" and 17 3/8" from edge and 2 3/8" from body line.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: '68 GTX quarter panel emblem holes... HELP!! [Re: 5wndwcpe] #1024781
07/04/11 01:59 PM
07/04/11 01:59 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
FYI - If you're using aftermarket emblems, I would locate one hole (say the front) off of the picture I had provided and use the emblem to locate the other hole. On an aftermarket piece, the pins may not be in the exact same location as the factory piece. I'd hate to see you drill them both and then find out the emblem doesn't line up.
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
Re: '68 GTX quarter panel emblem holes... HELP!! [Re: GI Moparman] #1024782
07/05/11 09:26 AM
07/05/11 09:26 AM
crlush Offline
crlush  Offline
Drill first hole then make a template using new emblem, then use template to locate second hole.
Re: '68 GTX quarter panel emblem holes... HELP!! [Re: 5wndwcpe] #1024783
07/05/11 09:18 PM
07/05/11 09:18 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
Here you go:
The right side is not the same as the left.
NMCA NSS 67 Coronet
Re: '68 GTX quarter panel emblem holes... HELP!! [Re: Barry70GTX] #1024784
07/05/11 11:24 PM
07/05/11 11:24 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Here you go:
Good point.
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
Re: '68 GTX quarter panel emblem holes... HELP!! [Re: 5wndwcpe] #1024785
07/06/11 10:35 AM
07/06/11 10:35 AM
Thanks Guys!!!!!!!!!!!!! I really appriciate the help!! I know i can always count on moparts to come through for me on the need to know stuff!!!!
