Door on my Roadrunner won't close all the way #1024743
07/02/11 06:16 PM
07/02/11 06:16 PM
Woodbridge,CA
NAS Backyard Offline OP
Woodbridge,CA
I think someone tried to close my door with the lock down or the button in. I don't know for sure but it won't close all the way. My door lock lever came off along time ago and I haven't been able to lock it with the key, so I need to go into the door any way. The latch and strikers look ok, anything else to check?. It seems like this may have happened along time ago also. Thanks.
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: Door on my Roadrunner won't close all the way [Re: NAS Backyard] #1024744
07/02/11 06:21 PM
07/02/11 06:21 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
sounds like the lock levers are bound. easy fix but you will unfortunatly have to pull the inner skin off.
double check the latch on the outside and make sure it's in the 'receiving' position (maybe just a little WD-40)
