Kickdown help
#1024607
07/02/11 03:59 PM
07/02/11 03:59 PM
Posts: 2,623 Ca Registered: Mar-2001
hemiallen
Got a second hand, new Kickdown with the Hemi-orange bracket and 3 pc rods, no instructions. Car is a 74-360 challenger that had a home made kickdown,,,,, tranny is either fubar or hopefully this will fix the odd shifting up and down all the time.... Installed the bracket on the last holes in the intake, pivot on the bracket and arm connected to the carb, dropped the 2 pc down the firewall and don't see where/ if the section that holds the 2 arms together is supposed to mount to, or does it just hang in space ( Part labeled as #1-pivot pointed to) ? Here is the Image that I used to assemble it, and all parts to the top image are in my kit Does that lower pivot attach to the firewall somewhere? Thanks Allen
'05 Quad cab hemi truck- Flame red- magnaflow exhaust
70-440 cuda-
74-360-4v Challenger- new driver car
EX vehicles:
66 charger Drag car- 10.80 at 123 mph
57 imperial 392 Hemi
1960 Sanger V drive- mondello-built 392 hemi
Re: Kickdown help
[Re: hemiallen]
#1024608
07/02/11 04:15 PM
07/02/11 04:15 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Generally a smallblock E body, IIRC has a 1 pc rod for the main kick down that pivots off the intake mounted bracket, down to the valve body lever....however a 3pc could be used, as some where used in smblk B bodies,....item #7, not #1 that you reference for help in "location", is mounted to a boss (protrusion) cast into the transmission, which may/may not be on your transmission (depending on the year of mfg)....if the boss is present, use it,....if not, purchase the correct/new kickdown linkage from the host of assorted vendors in the reproduction market
Re: Kickdown help
[Re: OzHemi]
#1024610
07/02/11 04:23 PM
07/02/11 04:23 PM
hemiallen
The lower bracket does have a bolt on it, so I assume it mounts like in your picture.
Thanks, I'll go out and see if I can find the hole and bolt it up.
Allen
70-440 cuda-
EX vehicles:
Re: Kickdown help
[Re: hemiallen]
#1024611
07/02/11 04:55 PM
07/02/11 04:55 PM
hemiallen
Got the pivot bracket bolted on to the transmission, now the arm between the pivot and tranny is too long...
It looks like it wants to bolt to the transmission shifting bracket, not the arm coming out of the trans that is forward of the shift linkage.... arm is about 9 inches long, about 1 1/2" longer than the old rod linkage was connected to the transmission...
The shift linkage is behind where the kickdown is with no load, but to get the new linkage to attach to the upper kickdown bracket the kickdown arm needs to be on top of the shift arm location?
Not sure why, but the shift linkage in the above picture , the arms are swapped top to bottom , the longer unattached arm is about where the linkage arm front pivot of the shift linkage is, and where the pictured arm is that needs the kickdown attached is where the new linkage wants to be.....
Any idea why this image seems backwards from my trans setup?
Any suggestions?
Allen
70-440 cuda-
EX vehicles:
Re: Kickdown help
[Re: 52savoy]
#1024614
07/03/11 12:36 AM
07/03/11 12:36 AM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Ok then...the correct term is THROTTLE PRESSURE LINKAGE
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
Re: Kickdown help
[Re: 52savoy]
#1024615
07/03/11 03:12 AM
07/03/11 03:12 AM
Posts: 18,157 Mass
DAYCLONA
Mass
To be honest it's hard to say without knowing what linkage you have because it sounds like you've got a mismatch. There were more than just 2 styles. Some years had even more adjustment potential. It would be nice to see some pictures.
AZ69CHARGER... that's how you define helping someone by using semantics?
.....on both statements, the OP needs to post some pics, if possible, only so much you can do verbally,....and FWIW A-Z69Charger the Chrysler FSM list the correct terminology as throttle rod
Re: Kickdown help
[Re: DAYCLONA]
#1024616
07/04/11 02:08 PM
07/04/11 02:08 PM
hemiallen
And sorry, everyone else calls it a kickdown linkage, I believe, but I'll go with whatever makes you happy.
I will try and get a pict or 2 soon.
Happy 4th of July, or independence day to some
Allen
70-440 cuda-
EX vehicles:
Re: Kickdown help
[Re: hemiallen]
#1024617
07/04/11 02:46 PM
07/04/11 02:46 PM
hemiallen
Topside picture Lower trans bracket view from drivers side Lower linkage that seems too long, the existing kickdown with Block is forward ( left) clean Galv is new long rod and clamp, right is shift linkage. I put new bracket facing out for ease of visual, I know it is 180 degree's out, but you can see the "kickdown arm is forward maybe 2" from the new rod.... Thank you Allen
70-440 cuda-
EX vehicles:
Re: Kickdown help
[Re: hemiallen]
#1024618
07/04/11 04:20 PM
07/04/11 04:20 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
though not much help,when/if someone lets you know or shows pic of the correct piece you need,i most likly have it,as i bought boxes of kickdown linkages to get one piece i needed.i will look to see what i have that looks right,if i got it you can have it. i actually bought kickdown linkage from a shmoe,who claimed it was 6pak,but sent 360 truck linkage(since banned for screwing others)i'll look at that tonight see if i have something that can help you
Re: Kickdown help
[Re: hemiallen]
#1024619
07/04/11 04:32 PM
07/04/11 04:32 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
In the topside pic, you have the front end of the spring hooked in the slot, it should be hooked over the outer groove on the carb stud, inner groove gets a hairpin clip. (both visible in the pic in post one)
The original upper lever in the bottom pic is further forward because the inner hole in the lever is clocked differently than the new one, install the new one and it should work OK.
Re: Kickdown help
[Re: John_Kunkel]
#1024620
07/05/11 10:34 PM
07/05/11 10:34 PM
hemiallen
Yes, I noticed I didn't hook the spring to the linkage and it allowed some airgap, thanks for noticing it.
So John, your suggestion is to remove the old kickdown arm ( of course) and use the new clamp currently on the new linkage, I think that old longer arm won't work?
Shouldn't the arm on the transmission for the "kickdown" linkage float, it seems to seek, under no load, a position forward of the shift arm by maybe 2", so I assume if I install the new galvanized arm ( I see it has a rotation flat) and let it find it's location, the arm I have that looks too long needs to be whatever the length is from the pivot to the trans arm with no movement due to a different rod length?
Allen
70-440 cuda-
EX vehicles:
Re: Kickdown help
[Re: John_Kunkel]
#1024622
07/08/11 10:16 PM
07/08/11 10:16 PM
hemiallen
Thank you very much John.
Allen
70-440 cuda-
EX vehicles:
