transmission speedometer housing #1024550
07/02/11 01:47 PM
07/02/11 01:47 PM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
i a a 440/727 , does anybody have a diagram of how the speedometer gear is set up in the transmission, i have a leak coming thru where the speedometer cable hooks into to the transmission speedmeter gear
housing, i have attached a pic. , it is leaking from where the speedometer cable screws onto to the speedometer gear housing.
i am guessing that i need to take out the speedometer gear out of the transmission and there must be an o'ring in the center where the cable goes?
thanks
Re: transmission speedometer housing [Re: cornet684me] #1024551
07/02/11 03:47 PM
07/02/11 03:47 PM
Brandon, Ms
Brandon, Ms
Re: transmission speedometer housing [Re: cornet684me] #1024552
07/02/11 03:50 PM
07/02/11 03:50 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
There is a rubber seal in the housing that seals the pinion shaft, it's held in by a wire ring both of which are visible in the pic below.
Re: transmission speedometer housing [Re: John_Kunkel] #1024553
07/02/11 03:59 PM
07/02/11 03:59 PM
Brandon, Ms
Brandon, Ms
great,thanks for the pic. , pic is worth thousand words.
so i take off the bolt holding the retaining clip and slide the speedomter cable housing off and then it will be just like your pic.
then i somehow get the wire ring off and the take out the rubber seal and replace the rubber seal?
thanks
John, i really appreciate you taking the time and the trouble to post the pic., i have the car jacked up and trying to fix it and it is about 100degrees here and i am very hot and frustrated.
Re: transmission speedometer housing [Re: cornet684me] #1024554
07/02/11 04:06 PM
07/02/11 04:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, keep track of how it's clocked when removing. Just pick out the wire ring and seal with a hook, a 1/4" drive socket makes a good installation tool for both.
Re: transmission speedometer housing [Re: John_Kunkel] #1024555
07/02/11 04:10 PM
07/02/11 04:10 PM
Brandon, Ms
Brandon, Ms
Great, thanks for the help, i will post my findings, i think i will take break and do another day since already hot and frustated.
Re: transmission speedometer housing [Re: cornet684me] #1024556
07/02/11 05:24 PM
07/02/11 05:24 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
whatever happened with the fuel leak?
Re: transmission speedometer housing [Re: mikemee1331] #1024557
07/02/11 11:00 PM
07/02/11 11:00 PM
Brandon, Ms
Brandon, Ms
hey Mike, that is what i started out doing this weekend fixing the fuel leak and when i took the car cover off the car and jacked it up and was going to extend the rubber line up higher is when i noticed transmission fluid all under the speedometer cable on the tranny, so i switched from fixing the fuel leak to fixing the transmission leak since the fuel does not leak just sitting and the transmission is leaking while sitting.
Re: transmission speedometer housing [Re: cornet684me] #1024558
07/03/11 11:36 AM
07/03/11 11:36 AM
Knoxville, TN, USA
mantonas Offline
mantonas  Offline
Knoxville, TN, USA
Sorry to hijack this post, but I need to replace the speedometer pinion gear. How do you get it out? If you follow the instructions on this thread and remove the wire clip with a hook and the seal, will the "adapter" (that's what the parts book calls it) come right out? Then what do you do?
69 Chrysler 300 Convertible 77 Chrysler New Yorker Brougham 2-dr 03 Jeep Grand Cherokee Limited
Re: transmission speedometer housing [Re: mantonas] #1024559
07/03/11 11:53 AM
07/03/11 11:53 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
To replace the gear you remove the housing and pull the gear out and stick the new one in.it just sticks through from the inside.
Re: transmission speedometer housing [Re: stumpy] #1024560
07/03/11 11:54 AM
07/03/11 11:54 AM
Knoxville, TN, USA
mantonas Offline
mantonas  Offline
Knoxville, TN, USA
That's my question, how do you remove the housing? Will it come right out when you remove the wire clip?
Re: transmission speedometer housing [Re: mantonas] #1024561
07/03/11 11:58 AM
07/03/11 11:58 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You remove the bolt and y shaped piece that hold the housing in and pull the whole thing out.You don't need to remove the wire clip. Just be sure that you clock the housing to match the new speedo pinion. The instruction on clocking are in the tech archives. Put a drain pan under it because you will lose a couple of ounces of fluid.
Re: transmission speedometer housing [Re: stumpy] #1024562
07/03/11 12:28 PM
07/03/11 12:28 PM
Knoxville, TN, USA
mantonas Offline
mantonas  Offline
Knoxville, TN, USA
I tried that already, and it didn't pull out easily, so since it's made of plastic I didn't try to force it. Does it need to be turned before it will come out, or do I need to pry it out with a screwdriver a little to break it loose? (Or both?)
Re: transmission speedometer housing [Re: mantonas] #1024563
07/03/11 12:56 PM
07/03/11 12:56 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
If it's stuck, it's easier to remove the housing with the speedo cable still attached. After you remove the clamp and nut, grab the 1" nut which retains the cable to the pinion gear housing and start to wiggle the cable and housing as a whole, from side to side very slightly. It'll take some patience, but it should eventually break loose.
You can see on this black plastic housing where a screwdriver was used to pry it out.
'nother pic of the two plastic housings and the different pinion gear:
The pinion gear housing indexing picture Stumpy mentioned above:
Re: transmission speedometer housing [Re: In_The_Pink] #1024564
07/03/11 03:58 PM
07/03/11 03:58 PM
Knoxville, TN, USA
mantonas Offline
mantonas  Offline
Knoxville, TN, USA
Ok, so my transmission is sitting on the floor of the garage with no cable in it, but after finding out that there's nothing holding it in, I carefully grabbed it with a needlenose pliers and gently pulled it out.
Thanks a lot for the information, everybody. (How did we do this stuff back before the internet?)
Re: transmission speedometer housing [Re: mantonas] #1024565
07/03/11 05:33 PM
07/03/11 05:33 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
We broke stuff and had to buy it again.
"Just a Bracket car dressed up like a streetcar"
Re: transmission speedometer housing [Re: Just-a-dart] #1024566
07/04/11 03:44 PM
07/04/11 03:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Or we read the book.
Re: transmission speedometer housing [Re: John_Kunkel] #1024567
07/05/11 12:21 AM
07/05/11 12:21 AM
Brandon, Ms
Brandon, Ms
where do i get the rubber seal? and where do i get a new speedometer gear, i have changed from 2.76 to 3.55 gears and the speedometer is way off, i also have 150 lens on a 120 speedometer, i am wondering if i will ever get close enough with this to be able to trust my speedometer
Re: transmission speedometer housing [Re: In_The_Pink] #1024568
07/05/11 09:40 AM
07/05/11 09:40 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Hmmm...I think I have found the solution to a problem I haven't been able figure out for a long while....
Re: transmission speedometer housing [Re: cornet684me] #1024569
07/05/11 11:37 PM
07/05/11 11:37 PM
Brandon, Ms
Brandon, Ms
