Rocker shafts: are all rockers compatible? #1024470
07/02/11 01:38 PM
07/02/11 01:38 PM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
I saw this asked about a week ago, but I never read the replies. I have a 440 Source rocker set-up on my Indy SR heads, but I'm about to change over to either Indy or Harland Sharp rockers. It seems like the rocker shafts would all have to be the same diameter, because otherwise they wouldn't bolt onto the heads correctly. Is anyone using 440 Source or stock shafts with Indy, HS, or other brand rockers?
Thanks in advance for any help.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Rocker shafts: are all rockers compatible? [Re: 1968RR] #1024471
07/03/11 08:38 PM
07/03/11 08:38 PM
florida
74fldart Offline
74fldart  Offline
florida
from what ive seen, the shafts are the same O.D. im using stock shafts with crane iron rocker arms. On a motor had had in a car back in 05 i used stock shafts with erson iron rockers and havent had any problems with them.
Re: Rocker shafts: are all rockers compatible? [Re: 74fldart] #1024472
07/03/11 09:15 PM
07/03/11 09:15 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Some rocker arm mfgr's recommend hardened shafts if you are using roller rockers.
Re: Rocker shafts: are all rockers compatible? [Re: 1968RR] #1024473
07/03/11 11:55 PM
07/03/11 11:55 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Short answer, No.
Needle bearing rockers require a true .8750 rocker shaft that has a hardness of 50 hrc or more. Smaller diameter soft OEM shafts equal eventual disaster for needle bearing rockers.
Bushed or plain aluminum rockers need a hard chrome plated shaft to function correctly. Shaft diameter is not such a critcal dimension as it is with a needle bearing rocker. Most likely an OEM sized shaft will fit the bill as long as it is HC plated.
Stock steel stamped rockers can live with OEM shafts, which are not HC plated.
I have used the 440SCRAP stuff and wished I had not. I have used Indy rockers and got a refund. I spent the coin and got the HS and they were just right.
