Re: just to let you know
[Re: Clanton]
#1024455
07/02/11 01:48 PM
07/02/11 01:48 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
damn I dont know what to congratulate you on first?? CONGRATS!!
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: RodStRace]
#1024460
08/05/11 07:59 PM
08/05/11 07:59 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
it took a long time planning and paying off the bills so i would not be in debt at this time.next week is my last week at work.thanks for the kind words.I SUCK! i hope to go the the mopar race at norwalk in sept.i have been working on the new house every day replacing sidewalk,yanking 50yr old bushes with the pickup,chains.
[Re: Abodyjohn88]
#1024462
08/05/11 08:27 PM
08/05/11 08:27 PM
Clanton
northern,Ohio,USA
combo specs pleaseeee?
the current 1 i have in is comp cam roller grind# CRB3 4131B /4046B R 112.0 lash at .020 lift int .646/631exh dur at .020 291/306 valve timing at .050 open int 21 BTDC close 59 ABDC open exh 69 BBDC close 19 ATDC installed at 109 CL spec dur at .050 260/269 112 LSA
factory iron 346 heads 280/180 cfm at .600 blower shop teflon 8-71 @ 10%OD w/14 lbs of boost blowershop A/W intercooler meziere 136s pump[20gpm] 2x1250 cfm holley carbs 110 sq jetted 12.8 A/F ratio 8.5cr wiseco pistons[.030],eagle h rods,440source crank Koleno performance race block 5cross bolt mains . 727 w/A&A sun gears,billet drum,rmvb chetah.PTC vert 5k stall 3900lb car,driver.4.10/31' M/T 10.5 slicks,spool.
[Re: 6bblFLASH]
#1024465
08/05/11 11:47 PM
08/05/11 11:47 PM
Posts: 5,763 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Welcome Back! I really like that car and was wondering where you been. Congrats on....... Where do I start lol.
