70 b body non power brake push rod length #1024233
07/01/11 11:45 PM
07/01/11 11:45 PM
washington state
I
intomopars Offline OP
I
washington state
what is the correct length of the push rod( overall) for a non power brake disc brake 70 b body car also waht is installed lenghth from face of rear master cyclinder to end of push rod( where it bolts to brake pedal)
Re: 70 b body non power brake push rod length [Re: intomopars] #1024234
07/02/11 12:50 AM
07/02/11 12:50 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IIRC the manual master rod is 6 3/4" from the tip to the rod eye center, Mopar Performance has an adjustable manual rod, fit's all A,B,E applications, ...much better set up if you want to dial in the pedal height to your liking
