how much resistance for crank in just assmebled shrt
#1024152
07/01/11 07:37 PM
07/01/11 07:37 PM
Posts: 576 Hr up from KCK
451 D*O*D*G*E
Hr up from KCK
My crank is in and torqued nice,put all the pistons and rods together in right holes with moly and oil on bearing and oiled the pistons,gapped rings.This sucker is stiff to turn with balancer.Engine is a 451,i have never messed a bigger engine like this..is it normal to be stiff like this?Everything oiled.
1970 Challenger R/T clone
2010 Dodge Journey R/T black,awd,
Re: how much resistance for crank in just assmebled shrt
[Re: 451 D*O*D*G*E]
#1024154
07/01/11 08:08 PM
07/01/11 08:08 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Well when freshly lubed, the crank should spin nice and freely. If the crank alone was hard to spin, that's probably where the problem is. But with the pistons installed, it will make the assembly harder to spin for sure. Also, since you're using a piston with a shorter skirt, you may have a little less friction. And the choice of piston rings will affect resistance too e.g., 5/64, 5/64, 3/16 vs. 1/16, 1/16, 3/16.
Can you describe how hard it is to turn? You're talking without heads and spark plus installed right?
[Re: topside]
#1024158
07/02/11 12:27 AM
07/02/11 12:27 AM
451 D*O*D*G*E
Hr up from KCK
5/64 rings its the crank/rods/pistons.No heads.I used moly paste with a little 15w40 Rottella on bearings.Pistons dipped,put it soaked.I just got in so out of the shop for the night.I will put a beam wrench on it tommorow and report the reading.I think its the fresh rings,moly paste,15/40,not being us to turning a big block(my first).
It turn like butter with out the pistons/rods,turned ok till about the last two.I can turn it by the balancer by gripping it but takes alot of force.Engine was tore down with approx only 2500 miles on it for wiped cam and lifter,it ran great held 80 psi,reved like a 340,but had it pro honed,new rings i gapped and just am nervous a bit.I have learned alot about the b engine but still am a hair on the a** to many of you.Ill post the break away torque spec tommorow. Thank you guys big for the help.
...oh its a under cut fillet factory forge peice.
[Re: 451 D*O*D*G*E]
#1024159
07/02/11 02:07 AM
07/02/11 02:07 AM
Posts: 1,601 Hatfield,Pa.
bigD
Hatfield,Pa.
What are your rod/main bearing clearances. Was the crank ground or polished? If it was ground,did any of the rod journals require weld repairs? A reground weld repaired journal will have a larger radius than the factory under cut style,possibly causing bearing side clearance problems, D.
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
[Re: 451 D*O*D*G*E]
#1024160
07/02/11 02:08 AM
07/02/11 02:08 AM
Posts: 27,480 So Cal
autoxcuda
So Cal
What Troy had me do when I assemble my 416 short block was to check the rotating torque, with beam torque wrench, after each piston was installed and recorded that. You should see a linear progression of torque amount. Like after every piston it should roughly gain the same amount.
Careful trying to compare the gain in torque to another motor or build. The type and amount of assembly lube and assembly oil thickness, and just method of applying the lube can change those amount by a lot.
[Re: bigD]
#1024161
07/02/11 02:52 AM
07/02/11 02:52 AM
451 D*O*D*G*E
Hr up from KCK
Crank went in polished to its orig home( far as last run together),it is smooth.Hasnt been modified. I think the moroso moly paste i put on the bearing might be the culprit.I will post the beam wrench reading tomorrow
[Re: 451 D*O*D*G*E]
#1024162
07/02/11 03:04 AM
07/02/11 03:04 AM
autoxcuda
So Cal
Going to be tough to compare.
I assume the camshaft isn't in it either.
[Re: dOc …]
#1024164
07/02/11 08:57 AM
07/02/11 08:57 AM
RapidRobert
I'd say you're prob good. (as you know) rings have alot of drag. I would "shake" your rods, grab each one & move it back/forth to see if you have side clearance on the journal.
[Re: RapidRobert]
#1024165
07/02/11 10:43 AM
07/02/11 10:43 AM
451 D*O*D*G*E
Hr up from KCK
Yeah the rods shake nice.OK put the beam to it and gathered 38 lbs of resistance.Tell me im cool please!!I wanna get this jive turkey mostly together today!! Thanks all of ya for the help
[Re: 451Mopar]
#1024167
07/02/11 11:52 AM
07/02/11 11:52 AM
Posts: 4,848 Memphis
HemiRick
Memphis
I agree sound like ring friction to me.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Dodgem]
#1024169
07/02/11 12:09 PM
07/02/11 12:09 PM
Posts: 21,845 Kirkland, Washington
Pacnorthcuda
If block was torque plated it will turn smother once heads are on!
Good point! That would be an interesting before and after measurement. If in fact the assembly was free'd up once heads were torqued that would be pretty damn convincing evidence that a torque plate is MANDATORY!!!
[Re: 451Mopar]
#1024170
07/02/11 12:31 PM
07/02/11 12:31 PM
Posts: 30,486 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
38ft/lbs sounds OK to me?
Is that the break-away spec ...or after it gets rolling ?
[Re: dOc …]
#1024171
07/02/11 12:35 PM
07/02/11 12:35 PM
451 D*O*D*G*E
Hr up from KCK
Just honed no torque plate.The rolling pressure was slight less,ok i must be cool then,im getting back on the rest of it now,believe you me if i have any probs you guys will be the first to hear ,when its all done we'll celebrate with a you tube video of it running and drivin,hopefully within the next month!!!!!!!!!!!
