b/rb retainer seals from roadhazzard pics!! #1023922
07/01/11 12:56 PM
07/01/11 12:56 PM
Hr up from KCK
451 D*O*D*G*E Offline OP
Hr up from KCK
Installed the seals from member roadhazzard Greg,followed the directions to the tee,and was extremely happy with these static results.Ofcourse the real test is a prolong use of them but was very happy with the set up,you dont glue them in,you oil them in.Use stp or engine honey like the the directions say because if you use regular motor oil it will push the excess oil right down to the rtv you have at the floor of the block.I stopped with STP 3/8 before the bottom.This is a very tight snug fit and i went ahead and filled the back of the retainer in with hi-temp and squezzed it in hard right to the retainer seals.Looks bullit proof.
1970 Challenger R/T clone 2010 Dodge Journey R/T black,awd,
Re: b/rb retainer seals from roadhazzard pics!! [Re: 451 D*O*D*G*E] #1023923
07/01/11 01:01 PM
07/01/11 01:01 PM
Hr up from KCK
Hr up from KCK
Member name is roadhazard,one r.The pic of the rtv going to seals does go all the way to them.The pic casted a shadow were the sear dipped a little low right before the seal.
Re: b/rb retainer seals from roadhazzard pics!! [Re: 451 D*O*D*G*E] #1023924
07/01/11 01:05 PM
07/01/11 01:05 PM
Hr up from KCK
Hr up from KCK
Re: b/rb retainer seals from roadhazzard pics!! [Re: 451 D*O*D*G*E] #1023925
07/01/11 01:41 PM
07/01/11 01:41 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Jason, really is not necessary to fill in the retainer area with sillycone. The seals WILL do the job by themselves.
Looks like you trimmed the top of the side seals off They should be flush when installed and need No Trimming. Are you sure they were fully seated when installed?
Did the retainer and seals install with little effort? Ease of installation was the whole purpose of my redesign
Greg
Re: b/rb retainer seals from roadhazzard pics!! [Re: roadhazard] #1023926
07/01/11 03:20 PM
07/01/11 03:20 PM
Hr up from KCK
Hr up from KCK
Very simple i had no problems.The directions stated to leave 1/16 below retainer bottom and when i tapped with mallet(slightly) maybe a touch less than 1/16 was pokin up,i just trimmed the head off.Say thickness of creditcard.I just was trying to keep everything flush because i will rtv my windage tray direct to block.The seals were exact length of retainer so what mute amount ddidnt hit direct bottom definetly got into the rtv at the block.I think it will not only work great but makes the way the maufactuers want you to do it is a joke.I fully believe you on the rear not needing the extra sillycone but even though its r and d for you its me not wanting to have yank the mill either.But fully believe at this point no way is oil going passed your seals as you "Feel" the retainer pushing into the block!Thanks
Re: b/rb retainer seals from roadhazzard pics!! [Re: 451 D*O*D*G*E] #1023927
07/01/11 04:38 PM
07/01/11 04:38 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Good info Jason
Very simple AND easy to install is what I was after!
I can also appreciate not wanting to do the job over
Thank you very much for being my Guinea Pig
Re: b/rb retainer seals from roadhazzard pics!! [Re: roadhazard] #1023928
07/01/11 07:21 PM
07/01/11 07:21 PM
Hr up from KCK
Hr up from KCK
No problem Greg!Thank you for the nice product.
