11.75 rotor #1023468
06/30/11 03:57 PM
06/30/11 03:57 PM
NC
P
phil4161972 Offline OP
P
NC
Hey guys, I have a 72 cuda with factory disc brakes. I have an adapter to put the 11.75" rotor on that spindle. Will the Wilwood caliper adapters sold by Mancini bolt onto the spindle I have? Or is there a factory Pin type caliper adapter that will bolt to my spindle and work with the 11.75" rotor? thanks for any input.
Re: 11.75 rotor [Re: phil4161972] #1023469
06/30/11 05:11 PM
06/30/11 05:11 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
You may need a '73 Later A body spindle and a pair of AndyF's adapters...then the wilwood should clear any 15" rim, that's what I have on my 70 B body
WIZE
In Car:
Re: 11.75 rotor [Re: phil4161972] #1023470
06/30/11 05:56 PM
06/30/11 05:56 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
When I swapped a 70 E body from 70 E spindles to 73 A disc spindles, the 70 10.87 pin cal bkts bolted right up to the 73 A spindles. So I think the later B body pin or slider cal bkts will bolt to your 72 spindles - 10.87 or 11.75...
