70 roadrunner non a/c heater box #1023285
06/30/11 09:41 AM
06/30/11 09:41 AM
Winnipeg,Manitoba
cudablues Offline OP
Winnipeg,Manitoba
Does anyone know if its the same as one from a 69 Satellite?Thanks
Re: 70 roadrunner non a/c heater box [Re: cudablues] #1023286
06/30/11 11:29 AM
06/30/11 11:29 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Should work fine. The heater core is a bit different. You should be able to put a 70 heater core in it or use the 69 heater core which has different heater hose configuration under hood.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 roadrunner non a/c heater box [Re: 70gtx440dana] #1023287
06/30/11 12:52 PM
06/30/11 12:52 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
to expand on that a little: the '70 core (and the corresponding nipples on the WP) use two different sizes (5/8" and 1/2") unlike the '69 which use two 5/8" lines. This was done to prevent people from hooking them up wrong.....and most people do because the lines are supposed to "cross over" each other.
you can either change the core or the hose nipples, but if you want it to be correct looking, you need to use a '70 core.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 70 roadrunner non a/c heater box [Re: DPelletier] #1023288
06/30/11 09:44 PM
06/30/11 09:44 PM
Winnipeg,Manitoba
Winnipeg,Manitoba
Great,thanks guys,i plan on a new heater core anyways.As long as it looks right
