EASY flooding CARB. ???? #1022869
06/29/11 06:34 PM
06/29/11 06:34 PM
abc440 Offline OP
abc440  Offline OP
I have a eddy 750 electric choke carb on a 440. I changed the guts to a manual choke carb has according to posts on here 2 years ago. I have had trouble with it starting especially in hot weather. I blamed it on eddy carb and evaporation till now. I thinks it is flooding out real easy, can smell a little gas. Any ideas? THANKS DAVE
Re: EASY flooding CARB. ???? [Re: abc440] #1022870
06/29/11 07:22 PM
06/29/11 07:22 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
It's a combination of the ethanol in the fuel and that particular carb .
Re: EASY flooding CARB. ???? [Re: abc440] #1022871
06/29/11 11:55 PM
06/29/11 11:55 PM
I have had trouble with it starting especially in hot weather. I thinks it is flooding out real easy, can smell a little gas. Any ideas?
Next time b 4 you crank it see if the A/P still has a squirt (evap-lean) or misting (bad needle/seat-flooding). Recent prob or day 1. Spacer will prob benefit the evap if hood clearance allows. needle/seat assy's avail seperately
Re: EASY flooding CARB. ???? [Re: RapidRobert] #1022872
06/30/11 05:14 PM
06/30/11 05:14 PM
abc440 Offline OP
abc440  Offline OP
Would it help to turn the 2 idle screws on front of carb in a liittle bit? Thanks
