No Fuel To Carb.
#102265
08/10/08 11:11 AM
08/10/08 11:11 AM
Posts: 13,049 The Thumb O' Michigan
Fluffy
Automotive STD Guy
Automotive STD Guy
I figured my carb was being a PITA, but now I'm unsure. I have a 750cfm Elec. choke Edelbrock carb and I run a mechanical fuel pump. I really don't like the carb, but I don't have the funds right now to get something else. I would hope the carb isn't bad, it's only a couple years old with no much usage. Although, I'm unsure about the fuel pump, I cannot remember if it was new or from a junker I plucked. Where're some other place I can look to maybe find my issue? Thanks for any input.
Re: No Fuel To Carb.
[Re: Fluffy]
#102266
08/10/08 11:21 AM
08/10/08 11:21 AM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
take the fuel pump out, stick the inlet into your gas can with some fuel line and give it 2-3 pumps, there should be gas literally squirting out of it that fast.
Chances are the fuel pump is your problem.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: Fluffy]
#102268
08/10/08 11:39 AM
08/10/08 11:39 AM
goldduster318
Lake Orion, MI
if the little rubber diaphram gets any damage OR if its not properly seated on the eccentric, it won't work at all. I thought I had a bad fuel pump and it turns out there wasn't ANY gas in the tank since I had dropped it to put in a new filter sock wow did i feel dumb
[Re: moretoys]
#102270
08/10/08 04:55 PM
08/10/08 04:55 PM
Check your pickup tube in the tank, mine was restricted with rust and cause fuel starvation issue with my car.
[Re: moretoys]
#102271
08/10/08 05:10 PM
08/10/08 05:10 PM
Fluffy
Automotive STD Guy
Automotive STD Guy
sure there is gas in the tank?? sometimes the diaphram in the fuel pump might shrink.pour some gas/penetrating oil on the carb side of the pump,let it drain into the pump let it sit for a little while.(1 beer, or about 20 minutes)might bring it back too life.I have done this many times with success.Some brands of gas seem to make this happen when sitting for a long period of time.
Yep, filled all 22 gallons before setting it. I started it for afew minute a month back, if that ate it all... I'm in trouble.
[Re: OzHemi]
#102273
08/10/08 06:12 PM
08/10/08 06:12 PM
Fluffy
Automotive STD Guy
Automotive STD Guy
See if the pump is working... pull the fuel line going towards the tank, and stick a vacuum gauge on it and get someone to crank the engine over. It should draw a vacuum as it's cranking over, if not...time for another pump (or visa-versa and check for pressure coming out of the side going to the carb of course )
I was out earlier and just got one for cheap. I go to put it on and now I need a new fuel line.
I forgot to mention I have a newer fuel regulator(Holley) on after the pump, before the carb. If this goes bad, will it stop fuel flow? It's the newest thing on the system.
[Re: OzHemi]
#102275
08/10/08 07:18 PM
08/10/08 07:18 PM
Fluffy
Automotive STD Guy
Automotive STD Guy
I replaced the pump and the line to the carb. Still nothing coming up. This is an LA 360 in a 1995 Dakota. The original fuel pump is in, but gutted with a 3/8s line to the bottom with a sock on it.
[Re: OzHemi]
#102277
08/10/08 07:23 PM
08/10/08 07:23 PM
Fluffy
Automotive STD Guy
Automotive STD Guy
Could be the engine is not spinning over quick enough to prime up the new pump? Try filling the carb bowl with gas manually, and fire it up...see if that gets fuel up to the pump perhaps
Didn't someone with a yellow Demon do that and get a special smilie?
I'm fearful for that.
I'll retry tomorrow. Started to rain again.
[Re: Fluffy]
#102278
08/10/08 07:29 PM
08/10/08 07:29 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Please have a video camera handy... "just in case"
BTW...make sure the fuel pump is sucking too, if you have no luck still...
[Re: MoparforLife]
#102281
08/11/08 01:10 PM
08/11/08 01:10 PM
Fluffy
Automotive STD Guy
Automotive STD Guy
I'm not sure what I did, but I have fuel now. I'm nervous starting this, not sure why. How much is too much PSI on start up? I've got 5psi coming in and it was slowly going up. First try it backfired out the exhaust, so I fiddled the timing a bit. Second try it backfired exhaust then carb. I'm thinking it's getting too much gas. Or is my distributor out 180? I set it back the way I marked it, when it came out. I let it set to run the fuel back down for now. Thanks.
[Re: MoparforLife]
#102282
08/11/08 01:15 PM
08/11/08 01:15 PM
Have someone take an air nozzle from an air tank or compressor and stick into the fuel filler neck and stuff rags around it and pressurize the tank forcing fuel forward to the pump then crank over. Make sure that the tank has plenty of fuel in it.
I used a mityvac hand vacuum pump to draw fuel up to the fuel pump. worked pretty good
[Re: OzHemi]
#102284
08/11/08 04:19 PM
08/11/08 04:19 PM
Fluffy
Automotive STD Guy
Automotive STD Guy
Ok, I have it all set, it started. Next problem. It starts and stays at like 5,000RPMs I have an 1411 Edelbrock. 750cfm, Electric Choke. Is this just something wrong with my choke? I tried to bump the gas it to see if it would drop in RPMs and it doesn't. Thanks.
