What heat range?
#1021427
06/27/11 05:16 PM
06/27/11 05:16 PM
Posts: 475 HEMPSTEAD TX
CUUDAK
HEMPSTEAD TX
Trying to get an idea of what heat rang for the spar plugs on a B-engine with T6 80mm Turbo. I have only found two ranges colder? Any big block turbo guys tell me what they are using?
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: What heat range?
[Re: CUUDAK]
#1021428
06/27/11 08:59 PM
06/27/11 08:59 PM
CUUDAK
HEMPSTEAD TX
WOW! What is it? "Ancient Chinese Secret"
[Re: CUUDAK]
#1021429
06/27/11 10:27 PM
06/27/11 10:27 PM
Mancinis site has the best range chart in the business--use NGK's
[Re: CUUDAK]
#1021430
06/28/11 02:28 PM
06/28/11 02:28 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I went two steps colder.
What kind of boost pressure are you planning on running? That will change the heat range required. Thicker air is harder to ignite.
[Re: CUUDAK]
#1021432
06/29/11 12:37 PM
06/29/11 12:37 PM
feets
Senior Management
Senior Management
Irving, TX
You shouldn't need to go any colder than that. Chances are you'll be fine with a standard plug.
