Re: Dominator tuning....
[Re: Dunnuck Racing]
#1020415
06/26/11 01:28 AM
06/26/11 01:28 AM
Posts: 2,524 PA
moparacer
PA
Did you do transfer slot restrictors when you did the 2 circuit conversion?
If you did maybe go bigger with them.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#1020416
06/26/11 02:05 AM
06/26/11 02:05 AM
Posts: 2,309 Tomorrow.
Damned67
Tomorrow.
No, didn't do transfer slot restrictors.... But that's made me think of something.
Despite the idle A/F being spot on when I parked the car last year, it was quite rich this AM. Had to lean the idle mix screws and back the idle speed down. I could have closed the butterflys past the transfer slots. Regardless, I'm going to pull the carb off and check exactly how I've got it set up. It's been two years since I set it up, and I can't find the piece of paper where I recorded everything.
I'm not sure why the idle A/F was so good last year, and had to be adjusted this year. Guess I'll blow it all out with brake cleaner while I'm at it.
Re: transfer slots. I may be onto something there. This is from the Innovate forum: "Why would he want T slot exposure at curb idle?" "[try] having a "small" amount of primary slot exposed at idle. Most start with .020" or square. This helps prime the transition curcuit of the carb. Not haveing any slot exposed can sometimes cause a too lean condition right off idle. too much exposed will cause idle afr too be too rich reguardless of mixture screw setting"
I'll go back to that and start all over...
[Re: Damned67]
#1020417
06/26/11 03:30 AM
06/26/11 03:30 AM
Damned67
Tomorrow.
Wow, I really need to stop drinking! I lied, based on the jets installed in the body, I did do the transfer slot restriction..... Now just need to measure what it is.
Edit: TSR jets are 0.055" (#54 drill bit)
