440 rv cylinder heads #1019622
06/24/11 01:56 PM
06/24/11 01:56 PM
michigan
2
21966mopars Offline OP
michigan
I have a 76 440 rv motor, would a set of 516 closed chamber heads help if i use bigger valves and the hardened seats? or would I be better off using aerohead cylinder heads I already have the 516 heads and i am trying to do this on a budget.Not sure if it would be worth rebuilding the 516 heads or not.
Re: 440 rv cylinder heads [Re: 21966mopars] #1019623
06/24/11 03:47 PM
06/24/11 03:47 PM
Kansas
BEINGmeISaCRIME Offline
Kansas
I would think would be pretty close on costs to get your heads machined or to get a set of aero. I'd just make sure on whatever you may choose to have hardened valve seats.
Re: 440 rv cylinder heads [Re: BEINGmeISaCRIME] #1019624
06/24/11 07:35 PM
06/24/11 07:35 PM
dogdays Offline
dogdays  Offline
What are you planning to do with the motor?
I've been running unleaded in my '64Dog since I bought it in 1984 with no valve seat recession in over 70,000 miles. I don't agree that hardened seats are necessary. I'd be tempted to put a decent valve job on the 516s and run them while saving up for better heads and pistons.
I haven't been back to the board in a while but the last memories I have of Aerohead heads was that you couldn't just buy them and bolt'em on. Workmanship had been an issue. Maybe it's better now?
Re: 440 rv cylinder heads [Re: dogdays] #1019625
06/25/11 12:48 AM
06/25/11 12:48 AM
michigan
2
michigan
actually I may do a stroker motor in a few years, but right now I want more torque with the parts I have. .I plan on using a aluminum dual plane manifold,headers and a 750 holley.Do you think this would be a good combo with the 516 heads?
Re: 440 rv cylinder heads [Re: 21966mopars] #1019626
06/25/11 01:52 AM
06/25/11 01:52 AM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
despite the "expert" comentary you are sure to recieve, that combo will work just fine.the hardened seats are not a neccesity,and honestly,if you are going to go a whole new package route later,i wouldn't dump alot of money into the 516's. just a fresh valve-job and maybe .010/.020 off to ensure flatness.
Are you planning a cam change as well? the hughes whiplash series are a good choice, or a comp XE268 would do wonders for that combo.
Re: 440 rv cylinder heads [Re: superbyrd] #1019627
06/25/11 07:44 AM
06/25/11 07:44 AM
michigan
2
michigan
Thanks, I was planning a cam change when I rebuild the motor.The car is in the paint shop now so my budget is destroyed for a few years. So the goal is to have a strong running good sounding car and add more
H.P. later.
Re: 440 rv cylinder heads [Re: 21966mopars] #1019628
06/25/11 09:01 AM
06/25/11 09:01 AM
6T4 Polara Offline
6T4 Polara  Offline
Sent you a Email.
John
