Dirty Trailer, What cleaner? #1019550
06/24/11 11:20 AM
06/24/11 11:20 AM
DES MOINES IOWA
P
PARTSMAN440 Offline OP
P
DES MOINES IOWA
In the past I remember a cleaner for enclosed trailers that is suppost to be the shisnit discussed on this forum. Help.
Re: Dirty Trailer, What cleaner? [Re: PARTSMAN440] #1019551
06/24/11 11:23 AM
06/24/11 11:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Damn I forget the name of it but you can get it at the
dollar store
EDIT
its called Awesome
Re: Dirty Trailer, What cleaner? [Re: MR_P_BODY] #1019552
06/24/11 11:26 AM
06/24/11 11:26 AM
Spring City , Pa.
SIKPUP Offline
SIKPUP  Offline
Spring City , Pa.
Re: Dirty Trailer, What cleaner? [Re: SIKPUP] #1019553
06/24/11 11:59 AM
06/24/11 11:59 AM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Mike,
where do you get it. I need to clean up my trailer, I want to put it up for sale in the next week or so.
Re: Dirty Trailer, What cleaner? [Re: mopartony] #1019554
06/24/11 12:10 PM
06/24/11 12:10 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
It's called "Totally Awesome" I just bought some at Dollar Tree.
Do a google search they have a link on their web side for dealers.
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Dirty Trailer, What cleaner? [Re: DragDart360] #1019555
06/24/11 12:23 PM
06/24/11 12:23 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Wear rubber gloves
Re: Dirty Trailer, What cleaner? [Re: bigdad] #1019556
06/24/11 12:36 PM
06/24/11 12:36 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Got it at Dollar General. I cleaned the trailer last week and it takes all the tree stuff off. Makes it feel smooth again.
Re: Dirty Trailer, What cleaner? [Re: mopartony] #1019557
06/24/11 12:39 PM
06/24/11 12:39 PM
an8sec70cuda Offline
It comes in a clear plastic spray bottle w/ red lettering, but the liquid is a yellowish color. Might help you spot it on the shelf.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dirty Trailer, What cleaner? [Re: Todd] #1019558
06/24/11 12:42 PM
06/24/11 12:42 PM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
On my Classic I used soap and water and it worked out fine. Got ladder out went around it by hand about two hours looks great.I have heard great things about awesome. I have a bottle in case!
Re: Dirty Trailer, What cleaner? [Re: dare_dude] #1019559
06/24/11 12:47 PM
06/24/11 12:47 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Thanks guys!!
I will be hitting the dollar general or other type dollar stores to get a few bottles. might as well wash the bus with it too...
Re: Dirty Trailer, What cleaner? [Re: mopartony] #1019560
06/24/11 01:07 PM
06/24/11 01:07 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Thanks guys!!
works better when cutr with water to specific strength using it straight will sometimes leave clean streaks.
home of the
Sox and Martin Hemi Duster
Re: Dirty Trailer, What cleaner? [Re: HEMIFRED] #1019561
06/24/11 01:41 PM
06/24/11 01:41 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Thanks guys!!
I used a sponge mop with a long handle worked good. Rinsed with the pressure washer.
Re: Dirty Trailer, What cleaner? [Re: Todd] #1019562
06/24/11 02:54 PM
06/24/11 02:54 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Thanks guys!!
forgot to add do not let it stay on surface . do small sections and rinse immediately. if not the Awesome will leave marks of it's own.
home of the
Re: Dirty Trailer, What cleaner? [Re: Todd] #1019563
06/24/11 02:58 PM
06/24/11 02:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've used it straight and mixed... just dont let it
dry... I did my trailer a section at a time... then
I waxed it with a floor type wax... still looks pretty
good after 2 years and I dont wash it
Re: Dirty Trailer, What cleaner? [Re: MR_P_BODY] #1019564
06/24/11 04:16 PM
06/24/11 04:16 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
I have one of those brushes that the hose hooks to and the soap is pickup by the water as it passes through.
thanks for the heads up on the ins and outs of this stuff.
Re: Dirty Trailer, What cleaner? [Re: mopartony] #1019565
06/24/11 05:46 PM
06/24/11 05:46 PM
Chesterfield Twp. Mi.
John Burdine Offline
anyone use this stuff on a black trailor?
Re: Dirty Trailer, What cleaner? [Re: John Burdine] #1019566
06/24/11 05:54 PM
06/24/11 05:54 PM
Lehigh Acres, Florida
rickstershemi Offline
The Totally Awesome does a great job....for best results try not to wash it in direct sunlight and as stated do one panel at a time....also make sure if it gets on any glass surface to rinse with water immediately.....unless your trailer is covered in black streaks I would dilute it 50/50....I found that washing it more frequently with a diluted solution produced the best results
Rickster
Re: Dirty Trailer, What cleaner? [Re: John Burdine] #1019567
06/24/11 08:15 PM
06/24/11 08:15 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
yes, just do not let it dry on the surface, it will leave it's own streaks and dull the finish.
Re: Dirty Trailer, What cleaner? [Re: MR_P_BODY] #1019568
06/24/11 09:43 PM
06/24/11 09:43 PM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
LIKE MOP & GLOW????????
DO YOU APPLY IT STRAIGHT???
THAT PROBABLY LEAVES A REAL BARRIER & KEEPS THE POLISHED ALUMINIUM SHINEY??
Re: Dirty Trailer, What cleaner? [Re: V10nacuda] #1019569
06/24/11 11:07 PM
06/24/11 11:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I believe it was mop and glow and yes I put it on straight
