68 Charger window regulator #101882
08/09/08 02:01 PM
08/09/08 02:01 PM
White House,TN
stroked470 Offline OP
White House,TN
I just put the left rear quarter glass back in my Charger and I have a piece missing. I don't know what it is called or really how to describe it. It goes at the rear of the track and adjust the glass in and out. It looks like a stud that is adjustable with a roller on each end. One end hooks to the regulator and the other goes into the channel. I need that whole piece with both rollers. Anyone have a clue what I need and where to get it. I think the rollers could be bought new but I am not sure about the piece that they go on. I need this to finish putting the interior together in my car so I can drive it.
This stuff was taken apart when I bought the car so it disappeared before I got it home. The guy I got it from took little stuff like this apart without knowing how to put it back together. Now I am trying to figure it out from scratch. I bought another window regulator but it is missing on that one also.
Re: 68 Charger window regulator [Re: stroked470] #101883
08/09/08 07:28 PM
08/09/08 07:28 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Does this help you?
Re: 68 Charger window regulator [Re: DUSTER_340] #101884
08/09/08 07:28 PM
08/09/08 07:28 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Heres more
Re: 68 Charger window regulator [Re: DUSTER_340] #101885
08/09/08 07:29 PM
08/09/08 07:29 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Another
Re: 68 Charger window regulator [Re: DUSTER_340] #101886
08/09/08 07:29 PM
08/09/08 07:29 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Again.
In this photo there is a short double roller missing in the photo.That goes in the rear slots that you can see are empty.
Re: 68 Charger window regulator [Re: DUSTER_340] #101887
08/09/08 07:31 PM
08/09/08 07:31 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Last one closer photo.
Re: 68 Charger window regulator [Re: DUSTER_340] #101888
08/11/08 08:41 AM
08/11/08 08:41 AM
White House,TN
White House,TN
That is the piece that I need but what is it called and where can I find one.
Re: 68 Charger window regulator [Re: stroked470] #101889
08/11/08 11:28 AM
08/11/08 11:28 AM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Sorry that I can not help you with.I would think it would be called a roller guide, but I am not sure.Try posting over at dodgecharger.com and see if anyone over there can help you.
Re: 68 Charger window regulator [Re: DUSTER_340] #101890
08/11/08 11:52 AM
08/11/08 11:52 AM
White House,TN
White House,TN
I posted over there but that is a pretty slow board. I need to get this thing done. I want to drive this thing sometime this summer.
Re: 68 Charger window regulator [Re: stroked470] #101891
08/11/08 12:20 PM
08/11/08 12:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If I'm following you correctly the part you need actually has three rollers two capturing the track & one fits in the plate attached to the window... In & out adjustments are actually made to the track by loosening the lock nut & twisting the adjuster... If the piece with three rollers is what you need they were used on all 68-70 B bodies, I think 66-67 B bodies, plus similar vintage C bodies so they shouldn't be to hard to find....
Re: 68 Charger window regulator [Re: 1_WILD_RT] #101892
08/11/08 12:23 PM
08/11/08 12:23 PM
White House,TN
White House,TN
Yes that is exactly what is needed. I couldn't see that is had 3 rollers. I could only see the one on the other side with a flashlight to see what it looked like. I figured most people that had them would only want to sell them with the regulator as a unit and not break it up. I just bought another regulator and it was missing that part also.
Re: 68 Charger window regulator [Re: stroked470] #101893
08/11/08 06:34 PM
08/11/08 06:34 PM
Re: 68 Charger window regulator #101894
08/11/08 06:57 PM
08/11/08 06:57 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Hello Tom!! Good Picture!! He needs one of the three roller assemblies, do you have any???
Re: 68 Charger window regulator [Re: 1_WILD_RT] #101895
08/11/08 10:20 PM
08/11/08 10:20 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
I actually do not see three rollers.I believe that it is only two, one roller slides vertically inside the track, and the other moves horizontally within the window plate.
Jacks auto parts has a quarter window roller kit.
http://www.jacksautoparts.com/catalog/hardware.html
Re: 68 Charger window regulator [Re: DUSTER_340] #101896
08/11/08 11:43 PM
08/11/08 11:43 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The window roller kit doesn't include the diecast body that he needs...There are three rollers, one one either side of the stamped steel guide, they are spring loaded toward each other effectivelt clamped to the guide & one mounted on the other side of the diecast support...
Re: 68 Charger window regulator [Re: 1_WILD_RT] #101897
08/12/08 08:42 AM
08/12/08 08:42 AM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
I will agree that is the type for the front roller, but not the rear.The rear track is an aluminum extrusion and is meant to have the roller internal.The cross sections of the two tracks are completely different and the roller styles will not interchange.
Re: 68 Charger window regulator [Re: DUSTER_340] #101898
08/12/08 09:02 AM
08/12/08 09:02 AM
Columbia Station, Ohio
69RTSE Offline
69RTSE  Offline
Yep, double roller goes on the front, single in the rear...the kit from Jack's look right.
Re: 68 Charger window regulator [Re: 69RTSE] #101899
08/12/08 09:16 AM
08/12/08 09:16 AM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Here are some pcitues from the parts book and service manual.The slide is common to A,B or C bodies is part number 2841646 and the roller is part number 2520676 common to B or C bodies.
Re: 68 Charger window regulator [Re: DUSTER_340] #101900
08/12/08 09:19 AM
08/12/08 09:19 AM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Here is the service manual photo.
Re: 68 Charger window regulator [Re: DUSTER_340] #101901
08/12/08 09:20 AM
08/12/08 09:20 AM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
and the parts pages
