TORSION BAR INSTALL #1018240
06/22/11 02:34 AM
06/22/11 02:34 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Bought some .810 bars from a guy on racing junk. tell are stamped left and right. Question how to tell front from rear. There is yellow dots at one end on each.
Re: TORSION BAR INSTALL [Re: rickb67] #1018241
06/22/11 02:38 AM
06/22/11 02:38 AM
Cab_Burge Online work
Cab_Burge  Online Work
See if the L and R on are both ends, if not install them so you can read them from the rear of the trans. crossmember
Re: TORSION BAR INSTALL [Re: Cab_Burge] #1018242
06/22/11 02:54 AM
06/22/11 02:54 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Just ran out to the garage to check. They have an 446R and a 447l on each end.
Re: TORSION BAR INSTALL [Re: rickb67] #1018243
06/22/11 03:12 PM
06/22/11 03:12 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
Torsion bars have no front back. just a left right. pop 'em in and enjoy!
1971 Challenger
Re: TORSION BAR INSTALL [Re: cudazappa] #1018244
06/22/11 06:17 PM
06/22/11 06:17 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
go under google and type in torsion bar tango, there is a great article and pictures, it explains left and right twist, etc
Doug
Re: TORSION BAR INSTALL [Re: cudazappa] #1018245
06/23/11 03:00 AM
06/23/11 03:00 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
THANKS. I got one out to night other one i will have to make a tool to get it out or better than 2 1x2's screwed together.Heyit got yhe first one out. Spent an hour getting the converter in. guess it won't be fired up tomorrow night unless the calvary shows up.
Re: TORSION BAR INSTALL [Re: rickb67] #1018246
06/23/11 11:48 AM
06/23/11 11:48 AM
Central Coast
P
Plumcrazyracing Offline
P
Central Coast
odd number part numbers install on the driver side (left) and even number part numbers install on passenger side (right).
Re: TORSION BAR INSTALL [Re: Plumcrazyracing] #1018247
06/26/11 02:43 AM
06/26/11 02:43 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Bars are done engine in today and it runs. Drove it in the trailer and sounded greaT. Headed to the strip tomorrow.
Re: TORSION BAR INSTALL [Re: rickb67] #1018248
06/28/11 12:41 AM
06/28/11 12:41 AM
Montreal PQ, Canada
74_360_Cuda Offline
74_360_Cuda  Offline
Montreal PQ, Canada
Did you have hard time to install the seals?
I've just ordered a second set from Mopar because they have both teared at the molding line when trying to installthem. Themanufacturing date was 2011 but the rubber feels like it is 20 years old...
Re: TORSION BAR INSTALL [Re: 74_360_Cuda] #1018249
06/28/11 01:40 AM
06/28/11 01:40 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
No they were still plyable.But i had a friend that had a new set if i thought i needed them.
