Re: Apologies - what will this thing run? [Re: 67dodge67] #1018085
06/01/12 02:01 PM
06/01/12 02:01 PM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
Did you ever run your car at the track?? I still have some tires you can use.....
Re: Apologies - what will this thing run? [Re: boscosis] #1018086
06/01/12 02:29 PM
06/01/12 02:29 PM
fresno ca
mikeysmopars Offline
fresno ca
That sounds like a 12.40 formula to me, Let us know how you do!
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Apologies - what will this thing run? [Re: boscosis] #1018087
06/01/12 03:09 PM
06/01/12 03:09 PM
an8sec70cuda Offline
I know this is an old thread, but if that combo doesn't run 11s, then I'd be looking for a plug wire that fell off.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Apologies - what will this thing run? [Re: an8sec70cuda] #1018088
06/01/12 03:29 PM
06/01/12 03:29 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Hope the guy pops back in, I'm curious.
FWIIW my 10.2:1 450 w/ootb Eddys, 1.75 headers w/a 236@50 solid ran a best of 7.43 with a 1.62 60 ft. in the 8th with an 11 inch convertor.
I bet he ran at least the high 11's and should be mid low 11s.
Re: Apologies - what will this thing run? [Re: GwaiiEagle] #1018089
06/01/12 06:05 PM
06/01/12 06:05 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
11.88 at 114-115
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Apologies - what will this thing run? [Re: B3422W5] #1018090
06/01/12 06:32 PM
06/01/12 06:32 PM
Louisiana
Red440 Offline
Red440  Offline
Louisiana
I am thinking its full body and interior its pretty heavy for that 355 gear, and converter, 12 ohs , change to 4.30 and a good 8 inch converter 11.40's 117 mph. my
Re: Apologies - what will this thing run? [Re: Red440] #1018091
06/01/12 06:45 PM
06/01/12 06:45 PM
fresno ca
fresno ca
I Like this.... Moparts version of "PASSTIME"
I don't think its enough carb for the weight to do better than the 12.40 range.
Where's Brett Wagner when you need him?
Re: Apologies - what will this thing run? [Re: mikeysmopars] #1018092
06/02/12 07:04 PM
06/02/12 07:04 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I bet this combo is much faster than most think. Im guessing if this doesn't run 11.7s first time out id be looking for what is wrong with it. 11.5s easy. And a holley 750 is a great carb. Alot less to be gained by going bigger. Don't ask me how I know.
Re: Apologies - what will this thing run? [Re: viperblue72] #1018093
06/02/12 07:50 PM
06/02/12 07:50 PM
Tomorrow.
Damned67 Offline
Damned67  Offline
Tomorrow.
I think I've got a nice comparison.
My car is a '67 Belvedere, probably pretty close on weight.
10.4:1 505”. E'brock heads, 0.587/0.593 287/294 cam, M1 intake and 1050 Dominator. Mopar 175K converter (~2800RPM) and 3.55 rear end, and 8 year old firestone 205/70/14 street tires.
12.54 @ 114 w/ 1.932 60'
With converter, tires and gear, it should go nicely into the 11's.
