Again how much oil in a Strange S 60 with the aluminum #1018056
06/21/11 10:38 PM
06/21/11 10:38 PM
Mohnton, Pa
DodgeCharger Offline OP
Mohnton, Pa
I posted on this topic last week. So I put 1 1/2 quarts in my rear drove the car about 5 miles and the rear started to rumble on decel.
How much oil is safe to run on the street and do you think this low oil situation hurt the rear ?
Also I didn't exceed 60 mph.
Thanks,
Re: Again how much oil in a Strange S 60 with the aluminum [Re: DodgeCharger] #1018057
06/21/11 10:44 PM
06/21/11 10:44 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Did the lube come out of the fill hole when you put in the 1 1/2 quarts? or is that all you had? What's the recommended amount to put in?
Re: Again how much oil in a Strange S 60 with the aluminum [Re: rowin4] #1018058
06/21/11 10:49 PM
06/21/11 10:49 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
I run 2 quarts of Redline shock proof oil in my strange S60 w/ Aluminum cover. Working fine for last 5 years, race only...
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Again how much oil in a Strange S 60 with the aluminum [Re: rowin4] #1018059
06/21/11 10:49 PM
06/21/11 10:49 PM
Mohnton, Pa
Mohnton, Pa
The fill hole in the aluminum case is much higher than the factory stamped steel cover. Why I don't know. The factory leve would be perfect. But there is no way to judge.
Re: Again how much oil in a Strange S 60 with the aluminum [Re: DodgeCharger] #1018060
06/21/11 10:57 PM
06/21/11 10:57 PM
rowin4 Offline
rowin4  Offline
Getting back to your problem of gear noise. Who set up the gears? are they street gears or pro race gears. The 1 1/2 quarts should have been enough lube
Re: Again how much oil in a Strange S 60 with the aluminum [Re: rowin4] #1018061
06/21/11 11:04 PM
06/21/11 11:04 PM
Mohnton, Pa
Mohnton, Pa
I bought the rear right from strange. I am starting to think the rumble may have been from a low tire. The rear has a detroit locker in it and today I found my right rear was flat. I picked up a drywall screw on my test drive.
Re: Again how much oil in a Strange S 60 with the aluminum [Re: DodgeCharger] #1018062
06/21/11 11:07 PM
06/21/11 11:07 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
fill it no more than factory level, whatever it takes to get it there.
measure a std cover and fill to that hgt relative to housing.
At least thats what's been done round here.
Re: Again how much oil in a Strange S 60 with the aluminum [Re: DodgeCharger] #1018063
06/22/11 03:49 AM
06/22/11 03:49 AM
I think the Mopar factory spec on fluid capacity on the dana 60 is 5 pints, IE 2.5 quarts I have had one of the old Mopar drag seminar instructors(Tom Hoover) say to run only one quart in the Dana 60 and 8 3/4 for drag racing
