Vacuum idle #1017906
06/21/11 07:53 PM
06/21/11 07:53 PM
CA
mojavered Offline OP
CA
What is the minimum vacuum required at idle with power brakes?
71 Challenger RT
440 / 727 / 8.75
Re: Vacuum idle [Re: mojavered] #1017907
06/21/11 08:11 PM
06/21/11 08:11 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
You want at least 12-13 inches.
10 doesn't do it on a Challenger....
Re: Vacuum idle [Re: mojavered] #1017908
06/22/11 03:00 AM
06/22/11 03:00 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Mine work fine with 5 inches vacuum at idle. 1970 'Cuda, single diaphram booster.
Re: Vacuum idle [Re: jbc426] #1017909
06/22/11 03:11 AM
06/22/11 03:11 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I think it depends on the brake booster. Some don't seem to need as much as others.
