727 trans neutral Switch plug ( help please ) #101773
08/09/08 12:02 PM
08/09/08 12:02 PM
Rosedale B.C Canada.. Eh
Fargo Freek Offline OP
super gas
super gas
Hi Gang
Iam in the middle of wirering up my street rod truck and need a diagram of the 3 prong plug on the trany for neutral switch or is it for reverse lights as well? anybody got a wire diagram that I can go by to wire this thing up (THANKS)
I was the Black Warlock but now Iam the Fargo Freek 1950 plymouth fast back (custom) 1951 Fargo spring special 1996 Dodge 1500 Pu 2008 Magnum AWD The way I see it is If It doesn,t say MOPAR then what else is there. E Mail me @ nascar2000@telus.net
Re: 727 trans neutral Switch plug ( help please ) [Re: Fargo Freek] #101774
08/09/08 12:14 PM
08/09/08 12:14 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Out side prongs back up lights and center N safety switch wire. Back up light is in one side out the other so that when in reverse the connection is complete. The center to the prong on the starter relay. It is in essense completing a ground when the detent is in the reverse position.
Re: 727 trans neutral Switch plug ( help please ) [Re: MoparforLife] #101775
08/09/08 12:20 PM
08/09/08 12:20 PM
super gas
super gas
Ok Thanks A million
