Putting a supercharger on a 360? #1017609
06/21/11 10:40 AM
06/21/11 10:40 AM
Goodyear Arizona
midnite360 Offline OP
Goodyear Arizona
Do I have to build a motor specifically for a spuer charger, Or can I just slap one on the top of my engine and go? Engine is a 360 bored 60 over KB pistons Bullet racing cam 280 duration sitting at 9.75/1 compression.
Re: Putting a supercharger on a 360? [Re: midnite360] #1017610
06/21/11 10:45 AM
06/21/11 10:45 AM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
Forced Induction & Nitrous engines are usually lower compression engines with forged internals. 9.75/1 is a little high if you are wanting to run alot of boost, but if you tune it right and keep the boost inline with what your fuel delivery system can safely run, you should be alright.
I would think that going EFI would be a must to go boosted as well
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Putting a supercharger on a 360? [Re: shanker] #1017611
06/22/11 01:13 AM
06/22/11 01:13 AM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
Keep the carb if you like them. I much prefer the EFI but that is a prefrence. Like he said comp is a little high but you could invest in some meth injection to help you out there and you should be pretty good. I would probably be more worried about that .060" over block and adding a bunch of power to it...
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Putting a supercharger on a 360? [Re: CW25] #1017612
06/22/11 01:11 PM
06/22/11 01:11 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
compression is alitle high if you plan on adding much boost unless you go for E85,forged pistons and good rods are important if you plan on making power like most blown engines like to make. EFI is a nice feature but not realy nessesary. its mostly a question about how much power you are trying to make and how long you want it to last. not many blown smallblock mopars out there.
thats my blown smallblock thats not completed yet but well on its way.
