Re: 383 VS 440
[Re: CUDA8U]
#1017122
06/20/11 07:31 PM
06/20/11 07:31 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
The 440 for the same reason as the one I gave in your other thread. ....as I said, it isn't rocket science: the 383 and 440 are very similar only the 440 is 15% larger. Not sure what more you need to know ....and PLEASE turn off your cap locks. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
Re: 383 VS 440
[Re: DennisH ]
#1017124
06/20/11 09:18 PM
06/20/11 09:18 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
I'll be the "stand alone" here. Not knocking off the 440 at all, (I'm a 413 guy! ) but I'd go with the 383. It can go to 500hp, but it WOULD definitely need the better heads to start with. Other reasons for which many "may" say it's insane but: Less rotating weight (crank mass) in the motor. Strong rods (when NEW) proven to go OVER 6200-6500 rpms with a good safety margin to boot. Oversquare bore/stroke combo with a 1.89 rod ratio - great for HI-RPM HP, midrange to hi-end torque. Easy to obtain, cheap to build, but piston prices have risen lately! In otherwords, it's an overgrown 340!! Only drawbacks - it NEEDS a lightweight body to run really HARD to "coin" the sub 11 sec and faster brackets. Motor needs a "pro" type oiling system for the sub-12 sec brackets, which include enlarged main oil feed and return block passages and possibly external oil lines and filters. Helps make them live longer!! A little more work than whats needed on the 440, but they DO HAUL THE MAIL!!
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 383 VS 440
[Re: CUDA8U]
#1017125
06/20/11 09:28 PM
06/20/11 09:28 PM
Posts: 1,548 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Try the 383 with a 4.25 stroke and good heads, 496ci. Mine did 648 horse under 6k RPM and under 10:1. Hydraulic roller.
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger w 383 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1997 Ram B3500 Van 5.9 1991.5 W250 Cummins- Big Chief
Re: 383 VS 440
[Re: terzmo]
#1017131
06/20/11 10:17 PM
06/20/11 10:17 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
440 has bigger bore that helps un-shroud the valve and make more HP with the same heads. Also for the street the extra TQ is fun Any money you save buying a 383 will be lost when buying pistons. The differance in weight is minimal, not like the differance going from BB to SB and either big block build it is gonna be a pain to change plugs compared to the SB so the minimal differance in deck height don't really make it much easier. If the choice is 440 or 383 build the 440 every time. BTW after 67 the 440 and 383 used the same heads
Re: 383 VS 440
[Re: terzmo]
#1017137
06/21/11 09:31 AM
06/21/11 09:31 AM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
....read the want ads and for one example...you'll see..."mopar for sale...383 with 440 heads" If the thing was that great it would run it's own heads....
You see ads like that because the seller is UNEDUCATED about mopar big blocks ... FYI the 383 - 2bbl runs the EXACT SAME heads as the 440, only difference is the valve springs .
Re: 383 VS 440
[Re: JohnRR]
#1017138
06/21/11 09:55 AM
06/21/11 09:55 AM
Posts: 2,177 ill
dennismopar73
ill
400 block, stoker kit ,make 500 cci, street/race, lighter block, be had cheap, set rpm heads, mid to low 11s, could be able run in the 10 without whole lot work, jmo
