Re: BIG BLOCK VS SMALL
[Re: CUDA8U]
#1016670
06/20/11 05:34 PM
06/20/11 05:34 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
OK!!!!!
THIS IS WHY I ASKED.......NO REAL DEFINATE ANSWERS ON A 383VS440 I HAVE READ THAT THE 383 HAS THINNER CYLINDER WALLS AND WILL FAIL SOONER IF BORED.
AS FAR AS THE 440 I'VE READ THE 67-68 BLOCKS ARE BETTER,SO I GUESS ALL BIG BLOCKS ARE NOT THE SAME!
SO IS THERE ANYONE WHO HAS BUILT SEVERAL BIG BLOCKS AND PERSONALLY KNOWS THE DIFF. SPECS OF BIG BLOCKS?
THANKS FOR THE INPUT GUYS.......STILL UP IN THE AIR WHAT IS THE BEST BUILD I GUESS?
I've read articles that stated the mid 70's blocks are better than the 60's blocks...I have a 72 only 030 over and a 76 stroked to 498...happy with both
[Re: CUDA8U]
#1016672
06/20/11 06:13 PM
06/20/11 06:13 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
OK!!!!!
Here you go; everything you ever wanted to know about 440 blocks;
http://www.440source.com/blockinfo.htm
Basically, any 440 block in good condition can be used and the differences between them all are VERY minor.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: CUDA8U]
#1016676
06/20/11 07:57 PM
06/20/11 07:57 PM
DPelletier
THANKS,SO GUESS IF I PURCHASE A CAR WITH A 383 THEN I'M BUILDING THAT SINCE THE SPECS ARE SO CLOSE AND THE EXTRA PURCHASE COST WOULD OUT WEIGH THE HP/TQ OF A 440
If you are buying a car that has a 383 and it's an original 383 car and you want 500hp, then I would suggest stroking the 383 or using a 400 stroker (451 cu in) to get your 500hp. You can get it with 383 cubes, but it will be a much more radical build.
OTOH, if you don't care about originality, then you may be $$$$'s ahead to get a 440 anyway....it's not like 440 cores are all that expensive and you can use the heads and many misc. parts off the 383 anyway.
1974 'Cuda
[Re: CUDA8U]
#1016679
06/21/11 12:15 AM
06/21/11 12:15 AM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
OK!!!!!
Simple answers: Fewer dollars invested, simple mods, go 440 cubes, especially with a 3800-4200lb B-body car! Lighter car (by 700-1000lbs less or A-body), some dollars to invest in BETTER intake and heads, love the sound of a screaming big block, go 383 cubes, especially with a stick behind it!
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
