main girdle and windage tray? #1015296
06/17/11 11:10 PM
06/17/11 11:10 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
I have been wondering if I should use the stroker windage tray with the hughes main stud girdle on the low deck 500? Will the girdle act as a windage scraper?
Re: main girdle and windage tray? [Re: EV2CUDA] #1015297
06/18/11 01:01 PM
06/18/11 01:01 PM
good ole USA
moparlifer Offline
moparlifer  Offline
good ole USA
I used a Chenoweth speed and machine on my 511 and it bolted on with no machining and fit perfect.
Re: main girdle and windage tray? [Re: EV2CUDA] #1015298
06/18/11 01:03 PM
06/18/11 01:03 PM
organ
maximum entropy Offline
organ
i use both. i suppose the girdle would act as a "gross" scraper as it's kind of close to the crank.
