Radiator Water Flow Rate #1015025
06/17/11 11:12 AM
06/17/11 11:12 AM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
How fast should the water be flowing through the radiator at idle speed? With the cap off and looking into the radiator should it be a small trickle where it comes out of the rows and runs down, or a very noticeable stream shooting out of the rows? This is on a cross flow radiator.
Re: Radiator Water Flow Rate [Re: wtucker] #1015026
06/17/11 01:03 PM
06/17/11 01:03 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If the thermostat is not open you will get very little movement. It makes an effective cork.
Once it opens you should see a fairly strong flow through the radiator.
- Stu Harmon
