Re: van steering coupler upgrade?? HELP
[Re: NicksGarage]
#1014702
06/24/11 11:16 PM
06/24/11 11:16 PM
Posts: 1,728 ST clair shores MI
moretoys
ST clair shores MI
The van uses the same shoe/box coupler that you're vintage mopar uses.kit comes with new clip and new shoes/pin?.They just don't last.I really want too replace the system with an updated bearing/u-joint style.It will last longer and feel so much tighter.I e-mailed flaming river,see what happens.My searchs have found no upgrade,appears from around 2000 ish,the vans use a u-joint coupler,but the columns are different.Not interchagable.Hoping someone has done this,so I know what to order,I'm sure some creativety will be needed,I just don't know the product well enough too order the right stuff.That is the stuff from rock auto,I just want better.
