Engine dyno/run stand guys---how to keep it cool? #1014062
06/15/11 09:23 PM
06/15/11 09:23 PM
Truckville, the capital of NY
85_Ram_4speed Offline OP
I built a engine run in stand recently. I just fired up the first engine of hopefully many to go on it with decent results except for it getting to warm and having to shut it down. Problem is how do i keep them running cool?
Right now, I have an A-body radiator and a small 10" or 12" electric fan on it. Its obviously not enough.
Even though I have made the investment of building the stand to my liking, I am not crazy about spending a fortune on a really limited use system, but I can't have engines overheating either.
Suggestions?
Outcast Dodge guy.
Re: Engine dyno/run stand guys---how to keep it cool? [Re: 85_Ram_4speed] #1014063
06/15/11 09:31 PM
06/15/11 09:31 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
one way is just use a :total loss: system
Re: Engine dyno/run stand guys---how to keep it cool? [Re: bonefish] #1014064
06/15/11 10:02 PM
06/15/11 10:02 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Most dynos use a cooling tower that uses the large reserve tank for the absorber as a cooling water source as well.
I have a 1000 plus gallon tank pf water to draw from.
A friend of mine has a run stand that he uses a radiator with.He uses a flex fan on the engine,and uses a large shop fan to blow air across the radiator and he never has an issue.
Keith
Re: Engine dyno/run stand guys---how to keep it cool? [Re: Dunnuck Racing] #1014065
06/15/11 10:16 PM
06/15/11 10:16 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
A crude but effective way I've seen it done is with garden hoses and no radiator. Each open end of the radiator hoses had a garden hose adapter. Hook one up to a fawcet, and the other dumped into a drain.
Re: Engine dyno/run stand guys---how to keep it cool? [Re: 85_Ram_4speed] #1014066
06/15/11 10:38 PM
06/15/11 10:38 PM
AndyF Offline
AndyF  Offline
Running cold water thru a hot engine might not be a good idea. It is better to have a thermostat in the system and to get the block up to the correct temp so you can actually break the motor in correctly.
A cheap solution that will be safe is to just go find a really big radiator. You should be able to mount any size radiator on a run stand so why not put a really big one on there? Something from a truck or a C body or something like that. With an engine fan running you won't have any trouble keeping it cool. Use a fan shroud also. The shroud will help pull the air thru the radiator and it will make it safer to work around.
Re: Engine dyno/run stand guys---how to keep it cool? [Re: AndyF] #1014067
06/15/11 11:06 PM
06/15/11 11:06 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
Andy, it did have a thermostat. I just didn't mention it. Just open the faucet and fill the engine, then start it.
Re: Engine dyno/run stand guys---how to keep it cool? [Re: AndyF] #1014068
06/15/11 11:19 PM
06/15/11 11:19 PM
I have the radiator mounted not so close to the engine. I think on the big block I just did it was about 6-8 inches I'll guess from the water pump pulley. I did have an engine driven fan on it, but obviously being too far away and no shroud, its not going to be very effective. This is where I was hoping the electric fan pushing through would be enough---I guess not.
Yes, I have all sorts of room for any radiator on ther, so I will look for something big and cheap. Heck even a mid/late 90's ram has a good size unit and its aluminum. I thing the majority of the problem is just too small a radiator. Any other suggestions, I am open.
Outcast Dodge guy.
Re: Engine dyno/run stand guys---how to keep it cool? [Re: 85_Ram_4speed] #1014069
06/15/11 11:45 PM
06/15/11 11:45 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
i used the radiator that was in the car. a box fan workrd pretty well.
Re: Engine dyno/run stand guys---how to keep it cool? [Re: Deepockets] #1014070
06/16/11 01:55 AM
06/16/11 01:55 AM
montana
BANDIT Offline
BANDIT  Offline
montana
Here is a picture of my stand before I went to a mid 90's caravan radiator fan assembly. Both motors i have run in on it have never went above the thermostat during break-in. Radiator is real similar to the one pictured above. Left over stuff from from circle track days. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Engine dyno/run stand guys---how to keep it cool? [Re: BANDIT] #1014071
06/16/11 07:13 AM
06/16/11 07:13 AM
Not a great pic, but here is what I am dealing with. The radiator in current use was free, so I figured what the heck----even though in the back of my mind I figured it wasn't going to be enough. Guess I was right on that.
Outcast Dodge guy.
Re: Engine dyno/run stand guys---how to keep it cool? [Re: BANDIT] #1014072
06/16/11 01:53 PM
06/16/11 01:53 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nice stuff Jim
Got any more pictures of your shop? Would like to see what you've got going on in there.
Rich H.
Esse Quam Videri
Re: Engine dyno/run stand guys---how to keep it cool? [Re: 85_Ram_4speed] #1014073
06/16/11 08:51 PM
06/16/11 08:51 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Heres a better picture with original fan set-up. Zippy, shop is kind of a mess lately, cant seem to get other peoples stuff done and out of there so i can work on the E-body thats on the hoist. My German Shepard is not doing very well at running people off either. Jim.
4600 DA
